Walbro 525LPH single pump
http://www.anfittingsdirect.com/ptfe...fe_teflon.html
https://www.racetronix.biz/storeitems.asp?cc=825s-hose
Although I have finally learned how to cut the stainless braiding without fraying, the custom fittings for PTFE hose appears to be much easier to install with less chance of leakage than Earl's, or the Summit brand..
Might want to review post # 6 and #15 in link below.
BTW - stainless braid is heavy and not near as pliable as the synthetic braid. Read the how-to for attaching the connectors to PTFE. They suggest buying PTFE hose cut to length, but it looks as if it is as easy or easier to cut to length compared to stainless braided line. I use a cutoff wheel but make sure to use a face mask when cutting stainless if that is what you choose.
https://ls1tech.com/forums/fueling-i...uel-lines.html
You can get custom lengths but honestly the lengths already available should cover anything you need. You can specify PTFE lines once you select the length and AN size.
