Fuel pump recommendations
Would you happen to be running a 340 pump with a stock regulator? WS6's page stated it won't work and I'd have to upgrade to a vette setup which would put me way over budget as the reg kit is 140 bucks.
Yes, I'm doing it on 1 of my cars right now with the stock regulator. Fuel pressure at the fuel rail is measured at 58psi. A 255 and a 340 will usually be ok with the stock regulator, but a 450 will push through the regulator and raise the fuel pressure to something around 70psi.
So this is the kit I'm gonna go with. Could probably save a few bucks piecing one together but I want it as painless as possible. http://www.ws6project.com/user_stor/...oducts_id=8399
hmm, that's kit im looking into. Will it fit in factory location with no mods? I have patriot 5.3 l heads, MS3 cam, FAST 90/90 setup and true duals. After I rebuild my trans soon I know I need a new tune bc I have a **** one on there(just bought car) and I know my pump is weak. I don't plan on spray, but if I got brave, no more than 100. Im building trans for 800 hp. Figured this size pump to have more than a need.
Input
Input
Input
Input
car isn't cut and wont be, just a preference. so new wires will need to get run thru the top of pump housing? im thinking of just pulling tank when I send the trans out to the shop so no rush to get done. I can push it off lift into the other bay. I just think I would rather go with larger pump and not make it work as hard or worry about running lean on top end, esp if I do more work or add spray. Thanks
I never would've cut mine either so I don't blame you there at all, but since I modded it I already basically ruined it as far a re-sell....not that I ever would or will. If you drop the tank, it'll be easy to run the wires. Mine just run along the original ones to the top of the tank. It's only a bit of a pain if you "don't" drop the tank, then you have to lower it some and fish them up in there. And your reasoning is why I went with a 340 over a 255 also. Only issue I'm having is now the pressure is around 65/67lbs instead of 55. I'm sure regulator related but so far it hasn't caused a problem.
#33
Yep, a few years ago I'd never have done it but it did make things so much easier. If done correctly it won't be a problem or noticeable at all.
One issue I forgot to add was once in a while when the car is sitting the pump may come on for a second or so...I notice 20-40lbs on the gauge that was on 0 and hasn't been started? I don't hear it but notice the pressure gain. I haven't figured out why this happens yet.
#35
LS1TECH Sponsor
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
