WOT Air/Fuel Ratio
What does the A/F ratio change to on WOT? I know it's 14.7:1 (lambda)on part throttle, but I haven't been able to find any info. I know it goes to open loop at WOT. So I'm stumped. Surely the stock programming would not run an engine lean like it would on part throttle.
Originally Posted by JoeDirt
I beleive you want to target around 12.7 - 12.9 WOT for an na car and 11.7 - 12.0 for forced induction ??
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Hmmm, I'm wondering if the WOT A/F ratio on the 99' model years with the smaller injectors would be different, since the 98' models had bigger injectors and the 2000-2002' years went back to the same size injectors as the 98's for the remaining production?
