Fuel pressure/regulator question
Are you talking about something like this? https://www.texas-speed.com/p-5758-h...ator-8-an.aspx
But if its maintaining at tht pressure the tune can be tweaked a lil to make it work at 65psi. Alot of turbo are tuned with higher or less fuel psi.
I'm trying to find where I read that this could cause the pump to fail....I'd much rather just leave it as is. I'm on a very tight budget as it is and I still need a wideband and will probably need a new diff eventually.
As far as the c5 regulator/filter, I've been looking into this in depth and even on those, much bigger than a 255 lph pump combined with a stock return line results in higher fuel pressure than the regulator's 58 psi preset. Some that have used a 340 lph report being in the 70s for fuel pressure. Too much pressure does put excess load on the pump for sure and will overwork it but high 70s/low 80s psi of fuel pressure would probably be where the issues happen.
Your 68 psi shouldn't be too crazy and should be alright on the pump. Seeing your fuel pressure at full throttle in high load would be interesting to see if it is still 68 psi.
