trickflow / aeromotive fuel rail issue
Hello,
The fitment on my fuel rails has keeps the lower o-rings from sealing properly. The brackets seem to require an offset to better the angle and the rails lean on the pedestals that bolt the intake to the heads causing an issue.
Am I the only one with this issue? both rails and brackets seem identical/symmetrical from left to right, front to back.
Tfs-3068000r rails (trick flow by aeromotive)
Factory ls6 intake manifold (2002 camaro ss)
Siemens deka ls6 80lb injectors (60mm between O-rings)
Aeromotive told me they can look at it if I send them the intake/rails/injectors..... smh.
pics are shown with brand new o-rings
