tbi uprgade
tbi uprgade
Ok, I recently installed a Holley Terminator TBI system on my 5.3L and learned that in order to be able to use the stand alone nitrous system,( a single plate wet system), I would need to download the software for the Holley HP system. I've got the HP V5 downloaded but have not done the upgrade yet because of some questions. I've done an ICF for the timing retard and have also done the Pin map but I haven't found anything yet that tells me whether I need to change any of the other parameters (ie. fuel or injector mapping.) Should the HP system start and run with minimum inputs similar to the setup on the Terminator system. If I had a certified Holley installer shop located anywhere near me I would get with them. I just don't want to open up a can of worms by doing a "bad" installation.
