fuel pressure bleeding off
first crank of the key it just turns over and it could just be for a blip.second crank fires every time.
little history.
chasing an oil leak changed valve cover gaskets, intake gaskets, knock sensors and valley cover gasket. change cam sensor and finally the rear main..... all had seepage but the rear main ended up being the problem. oil leak solved.
on to the next issue, not starting on the first crank.changed the regulator, changed the pump. so now im at a loss.... changed the regulator again thinking it was bad because it sounded like a kazoo. did the same thing with the new one. (no fuel in the vacuum line off the regulator.)
I checked the pressure at the rail and it is good on the first turn of the key it jumps up to 55 or so....but wont fire. after about 5 min I can try it and i would say 50-50 it will start on first crank. the pressure does bleed off over night. so thinking I have a bad pump I change it again......
so 2 pumps 3 regulators and a new filter...... am I missing something? Injectors? or something else? did i overlook something on the gasket changes? cam sensor?
Thanks all!
D
SPTURBO. it will fire every time on the second twist of the key.
STEVIETURBO haven't seen any codes. i suppose it it time to take it to a scanner.
Chances of a damaged computer through improper wiring or testing....much higher.
And you deleted your last post, so clearly something has changed since then ? And you still havent done the most basic first step...are there any faults reported by the ecu ?
stock wiring nothing has changed from the factory.
trying to get it in to a reader. with my generic reader there is no faults no pending codes.
Once I get it read ill post findings.
odd. never heard of that.... but ok. been doing it for several years now. more annoying that anything.
