Fuel return/feed question
Curious on a technical issue regarding fuel line routings.
I currently have a -6 feed coming into the FPR. From there is a feed to pass side fuel rail. Then back side of fuel rails is the cross over to driver side fuel rail. Then from the front of the driver side fuel rail is the line acting as the return back to the tank/pump. I have included a picture with arrows to show.
My question is if this routing is correct. And if not, would it be smarter to go to a routing that mirrors the picture supplied by Aeromotive.
The best way to do it is the diagram from Aeromotive.
You can also use the FPR in a dead end system.
I am speaking of the diagram, not the photo. The Aeromotive diagram is correct
I just figured out the photo. It IS wrong. If he goes by the Aeromotive illustration below it it will be right.
I clarified my original post.
This is how the system was set up on a recently purchased car. I had a large feeling that this wasn't correct at all but wanted some clarification. I fully intend on going off of the Aeromotive setup.
The issue that was leading me to assuming this was incorrect was the fact that the car needs to prime three separate times or so in order to actually fire/start. It's tuned on Sunoco E85R. The current start procedure is "Key on, let it prime, ign/start, key off" three times. In each procedure, it'll hold 50 pounds of fuel pressure. The second time it'll usually start to fire but not fully. The third or fourth time, it'll actually start.
Am I correct in assuming the starting issue lines within how the lines are routed/plumbed?
