Basic Fuel flow question on hose diameters
I find one site that states flow is directly proportional to the ID of the lines. Suggesting that 2 -6AN would flow similar to 1-12AN.
Yet I find another that says Area = Pi * Radius^2 which would indicate that the -12 has a greater area and flows more than than 2 -6's?
2' pizza - 3.1416 x 1 x 1 = 3.1416
4' pizza - 3.1416 x 2 x 2 = 12.5664 (4 x the 2' pizza)
Although I did see someone post ages ago that just because a pair of hoses may calculate as the same area as a larger single...does not mean they flow the same. Can't recall his reasons though...might have been due to surface friction etc within the pipe ?
Interesting calculator here...Certainly putting numbers into this, a pair of small hoses flows nowhere near a single larger hose at the same pressure usng -6 and -12 as comparisons.
https://www.copely.com/tools/flow-rate-calculator/
Looking at that fluid flow calc. It seems the larger line is leaps and bounds better?
-6 hose at 12 ft and 3 bar = 5.9 lpm 354lph (x2 708lph)
-10 hose at 12 ft adn 3 bar = 32.76 lpm 1965lph
-12 hose at 12ft and 4 bar = 57 lpm 3420lph
using 3/8 for -6 or 9.53mm.
using 5/8 for -10 or 15.88mm
using 3/4 for -12 or 19.05mm.
Feel like I did something wrong.
Reason I ask is guys seem to be getting more out of these AEM380 pumps by running separate -8 lines from each pump to each rail. Than guys merging -8 lines into a single -10 or -12 line. I'd think it would be the other way around.
This guys at a steady 13.5v and trapping 182 in a 3000lb setup. Yet others run out MUCH sooner with dual AEM's and "Y" in the system with a single larger line.
Unless you were making a **** ton of power on methanol or something though...-12 feed line does seem a tad excessive.
Although I would do a -12 from tank to pump as it's just a gravity feed, via a suitably large filter for each pump.
Aleck
