Racetronix Hotwire to Empty Out Old Fuel
Old Nov 7, 2020 | 09:21 AM
02TransAm/Batmobile's Avatar
Default Racetronix Hotwire to Empty Out Old Fuel
Hey guys, I need to empty my tank of old gas and I came across a post by saying it's possible to do this easily by hot-wiring the Racetronix wire kit to activate the fuel pump and pump out the old gas. Anyone know how to do this with the Racetronix kit?
Thanks in advance.
Old Nov 22, 2020 | 06:47 PM
Billiumss's Avatar
if you have HP Tuners, just turn on your pump through the scanner
Old Nov 23, 2020 | 09:48 PM
91 Z28's Avatar
Thanks in advance.
Why not disconnect a fuel line and turn the key to the on position?? The pump will just keep running because it can't pressure up the system
Old Nov 24, 2020 | 02:23 PM
dixiebandit69's Avatar
Pretty sure that won't work; the system is set to prime for a few seconds, then shuts off if there's no start.
Can confirm, there have been plenty of times where I had a fuel line off, and someone else turned the key on or reconnected the battery, and it'll spay for a few seconds and stop.
One time I got sprayed right in the chest this way...
Old Nov 24, 2020 | 05:11 PM
91 Z28's Avatar
Hmm must be a 4th Gen thing or the stock computer thing cause on my Holley 3rd gen my pumps keep going
Old Nov 26, 2020 | 03:29 PM
Because that's an aftermarket setup, not factory.
Old Nov 26, 2020 | 08:49 PM
91 Z28's Avatar
There is a way to do it on a stock setup, I just can't remember
Old Dec 3, 2020 | 11:31 AM
LilJayV10's Avatar
unplug the relay, run a jumper wire from 30 to 87 on connector. You are jumping power from the battery power 30, to the fuel pump power wire 87. Just use the same gauge wire for a jumper that's on harness.
pump will run continuously and you don't need the key on either.
