**UPDATED** Fuel pressure dropping on boost referenced setup.
Old Jun 11, 2023 | 07:12 PM
  #41
91 Z28's Avatar
Originally Posted by 30th t/a
Found this today. After I wrapped the screw with teflon tap, I took it for a 4th gear wot pull, 5900 rpm seeing 12.9psi of boost, fuel pressure was at 60.34psi.
Compared to the other day, 4th wot pull, 5900 rpm boost was 13.1 and fuel pressure was 52.86psi.
Should do away with that silicone hose and barb fitting and get a push lock fitting and hose on there.
Old Jun 25, 2023 | 09:18 PM
  #42
No Juice's Avatar
Everything working as it should now?
So still at about 60psi FP at 13#'s boost? What was base fuel pressure?
Edit.......have you tried disconnecting the BAP to see what the FP does now that the regulator is working properly?
Old Jun 25, 2023 | 09:21 PM
  #43
91 Z28's Avatar
If his regulator is a 1:1 rise then his base pressure would be 47 psi
Old Jun 26, 2023 | 12:05 AM
  #44
Dian's Avatar
"After I wrapped the screw with teflon tap,": so it seems you solved the issue?
"Tested regulator with a gauge and compressed air.
10PSI and 15 psi. The regulator and in car F.P. gauge responded perfectly.": was that done at full flow? what was the setup. just curious.
if i understand correctly, you were originally chasing a 6 psi drop. i would not have worried about it, but that just me. on one car i currently have a 15% drop in fp and just tune around it. a stock ls1 corvette has a drop of about 10%.
Old Jun 27, 2023 | 09:56 AM
  #45
RonSSNova's Avatar
I discovered the same issue on the adjustment screw of my Holley FPR.
Testing with a MityVac that produces pressure, it would bleed off quickly. Put Teflon paste on the threads, problem solved.
My FP now rises 1:1 with boost.
Tuning around stuff like this makes no sense to me.
Old Jul 17, 2023 | 06:47 AM
  #46
No Juice's Avatar
30th t/a - Did you get this thing on the dyno yet ?
Old Aug 16, 2023 | 12:41 PM
  #47
No Juice's Avatar
bump ............to see how this is running? on the dyno?......final thoughts? .........I mean it has been a couple months..lol
