Labor hours to swap fuel lines & components
I've got the '98 Camaro in my sig. My normal shop (who doesn't always satisfy my OCD) installed my current aftermarket fuel regulator near the OEM filter location, and filter is behind rear passenger seat back cushion. They said it'd be quicker than running all new lines up to the engine bay and equally reliable. But they oriented the regulator adjustment screw too close to the chassis and I can't adjust it as installed. I still have random fuel pressure drops on heavier throttle tip-in and I'd prefer to have the regulator closer to the fuel rail but unsure of preferred location for aftermarket filter in correlation to regulator. I know it needs to be between tank & regulator, but closer to tank, closer to regulator, etc. I still have the EVAP stuff on the driver side of the intake manifold.
So I checked out another startup shop today that commonly works on older Fbodies and is hungry for work. The owner estimates 6-8hours @$100/hr in labor alone to change from what I currently have to the desire routing. Does that seem excessive? But when I also inquired about my normal shop being unable to reliably locate the source of a coolant smell after pressure testing, this guy said coolant was designed to evaporate from the recovery tank. So for that reason I'm not confident in his skills and maybe I'll just have my normal shop do it.
What I have installed:
* AllStar Access Panel Kit ALL18534 for (1998) fuel tank trap door. Not modified for plastic tank.
* 1999-2002 plastic tank conversion
* WS6Store 1999+ complete fuel pump assemby kit (https://www.ws6store.com/product/99-...d-up-to-800hp/)
* Wix 33311 fuel filter
* Fuelab 51502 fuel regulator (https://fuelab.com/51502-fuel-pressu...in-6an-out/p10)
* Fuelab 71501 gauge (https://fuelab.com/i-193-efi-0-120ps...uge-71501.html)
* AEM 30-0301 plumbed in right before OEM fuel rail inlet (connects to pillar gauge)
* OEM LS3 fuel rail
* Autometer 2246 plumbed into EGR harness for scanning fuel pressure with HPTuners, sender connected to OEM fuel rail test port
Spare parts on hand:
* Qty 1 Fuelab 81801 fuel filter (https://fuelab.com/81801-6an-inlet-o...-10-micron/p56)
* Qty 1 Fuel 14502 Spare regulator mounting kit (https://fuelab.com/14502-regulator-b...dware-kit/p160)
* Qty 1 Aeroquip FCC0615-06AN teflon racing hose - 15ft (OD is ~11.2mm, wall ~2mm, so ID is ~7mm) ( )
* Qty 2 Russell 640863 fittings (https://www.russellperformance.com/6...sh-640863.html)
* Qty 2 Russell 640853 fittings (https://www.russellperformance.com/6...sh-640853.html)
* Qty 1 Dorman 800-085 Quick Connector 3/8 In. Steel To 5/16 In. Nylon Tubing (https://www.dormanproducts.com/p-20639-800-085.aspx)
* A handful of unused miscellaneous AN6 fittings
The car will remain NA, the goal is 500-550RWHP. Does this design look right?
Fuel Feed 1: Sender feed pipe > Russell 640863 (5/16 F QD to 6AN Male > Aeroquip FCM 1103 (6AN Female to 6AN teflon hose) > Aeroquip FCC0615-06AN hose > Aeroquip FCM 1103 (6AN teflon hose to 6AN female) > Fuelab 51502 inlet
Fuel Feed 2: Fuelab 51502 outlet > [unknown specific parts] > OEM fuel rail inlet
Fuel Return: Fuelab 51502 return outlet > Aeroquip FCM 1103 (6AN teflon hose to 6AN female) > Aeroquip FCC0615-06AN hose > Aeroquip FCM 1103 (6AN Female to 6AN teflon hose) > Russell 640863 (5/16 F QD to 6AN Male > Sender return pipe
EVAP: Sender pipe > Russell 640863 (5/16 F QD to 6AN Male > Aeroquip FCM 1103 (6AN Female to 6AN teflon hose) > Aeroquip FCC0615-06AN hose > Aeroquip FCM 1103 (6AN teflon hose to 6AN female) > [unknown specific parts] > EVAP inlet
Any other significant parts or design suggestions? Are the AN sizes appropriate? I'd like to find the right balance of flow & pressure to make the system rock solid.
Edit: Oh, I need some high-quality external sleeving for the hose also.
* OEM LS3 fuel rail
* OEM LS3 fuel rail
* OEM LS3 fuel rail
