open injector circut
I did seal up the knock sensor caps with silicone to prevent further contanination by water....
All appears to be connected correctly i have a worthless Haynes book so trouble shooting is difficult at best...
The car starts and runs fine for about 1.5 min after the codes are cleared then goes to rough idle.... I checked the pins in all the electrical plugs and all appear to be unbent... Plugs are ac delco double platinums gapped at .060 as specd.... Any help PLEASE
DABWS6
I have to use PP3 because the dealership would not recallibrate the speedo...
It has allways had 93 oct fuel with about 5 gallons of sunnoco 103-106 oct unleaded run through it monthly.....
Any suggestions on injectors/rails whats the best bang for the buck?? With the sealed ram airbox the hood has been opened for better flow no baffles the MAF ends make it run a little lean but not to bad... car has never thrown a code until this .....
Thanks
well lessons learned.... Thx agagin
