Who drives in the rain?
Old Dec 7, 2004 | 11:11 PM
SuperC1's Avatar
Default Who drives in the rain?
O.K guys here the issue. I drive my car back and fourth to work everyday. Lately its been raining a lot and my car has been running like crap. It seems that I'm having some fueling issues dealing with the O2's. When I scanned it B1S1 was pegged out at 11.3mv. What's causing this? Does anybody know? I've checked all the wiring it all looks good I even wrapped my O2 extentions to keep them from getting wet and still I'm having the same problems. Does anybody have a clue about whats going on here.
Old Dec 7, 2004 | 11:47 PM
2MuchRiceMakesMeSick's Avatar
Hummm my car drive like crap in the rain too... never did until i started modding. I would also like to know.
Old Dec 8, 2004 | 12:14 AM
mjgjr72's Avatar
runs like crap, like a missfire crap, check your wires for chaffing cracks may be arking when wet, 90 percent of the time is the cause of a car running like **** in the rain
Old Dec 8, 2004 | 04:34 AM
Keenov's Avatar
What O2 extensions are they? Ones that came with the headers? Or ones that you bought that just connect straight up?
My car is a daily driver, so it sees all sorts of weather and it does not have any problems.
Old Dec 8, 2004 | 07:40 AM
ruck98's Avatar
My Car Dosent Realy Run Like Crap But Say Im Going About 50mph It Like Something Is Holding It Back
Old Dec 8, 2004 | 08:08 AM
NBM2001z28's Avatar
Restricted User
it was an 02 for mine, felt ike i was running on like 100 hp.... the connection for the extensions are probably wet. did you put any grease in them?
Old Dec 8, 2004 | 10:16 AM
777's Avatar
777
i'd say it is your 02's or some fauty wiring...mine runs fine in the rain...
Old Dec 8, 2004 | 11:00 AM
SuperC1's Avatar
Got brand new plugs and wires, checked them all.
Old Dec 8, 2004 | 11:01 AM
SuperC1's Avatar
I wrapped them with a waterproof seal. Do they need di-electrical grease on them also???
Old Dec 8, 2004 | 11:03 AM
SuperC1's Avatar
Thats it, its not fueling properly. But it only happens when it rains.
Old Dec 8, 2004 | 11:08 AM
SuperC1's Avatar
I used the ones I bought with the hooker long tubes I purchased. They plug directly into the place where the sensor was originally plugged.
Do I need to get rid of them?
Old Dec 8, 2004 | 04:32 PM
SuperC1's Avatar
Anybody else drive in the rain???
Old Dec 8, 2004 | 05:21 PM
Phoenix 5.7's Avatar
all the time and no problems, but then again im stock for now.
Old Dec 8, 2004 | 07:46 PM
SuperC1's Avatar
Nomally it starts to happen when you add long tube headers and O2 extentions, but I can't tell if its the extentions that are bad or if I just need to replace the O2 sensor. But if the sensor was bad the car would run crappy all the time all the time, not just when the streets are wet.
The hesitation and sputtering makes you think that its in the plugs, but its not.
Old Dec 8, 2004 | 07:52 PM
cyphur's Avatar
This is an interesting issue. Is it suggested to use di-electrical grease when installing o2 extensions? I'm about to install headers in a few weeks and will definitely do so if thats the case, my t/a is my only mode of transportation.
Old Dec 8, 2004 | 09:11 PM
KySilverado's Avatar
How about another theroy. Long Tube headers transfer heat much better than stock manifolds. Now throw some water on them.... exhaust gas temperatures go down and effectively put the o2's to sleep? A logging scanner is what you need. I have LT's and its a daily driver. No issues with driving in the rain. Fairly fresh o2's up front, and brand new Bosh units in the rear.
Old Dec 10, 2004 | 12:42 PM
robertbartsch's Avatar
GM has another defect.
Take your intake manifold off. You will find your rear knock sensor is swimming in water from the rain.
Replace the sensor and silicone the wire plug to the valley cover.....
Your car will run fine in the rain now...
Old Dec 10, 2004 | 12:45 PM
Default Ruff in the rain? - your knocks are swimming in H2O
My car ran like **** in the rain.
I took the intake manifold off and found my rear knock sensor was swimming in rain water....
Replace the sensor, silicone the wire plug to the valley cover and your car will run fine again...
...Another GM defect bites the dust...
Old Dec 10, 2004 | 06:39 PM
SuperC1's Avatar
How did the water get in there?
Old Dec 11, 2004 | 01:32 AM
SmokingWS6's Avatar
I'd think the engine heat would evaporate the water in the KR sensor valley, no? I got stuck in a flash flood once, could hardly see in front of me, but it still ran fine.
