Aluminum or braid line
Which would be better. Aluminum is ALOT cheaper and not that bad to work with.
I only PRO on aluminum I have seen at shops is when you get bad fuel. As sunoco had a new additive that was eating away at the rubber in all cars. and a few local guys needed all new braided lines tank to rails! where the stock or aluminum guys only needed new injector seals.
Even if you get the (and I say it softly)cheap stuff from XRP it's still better than steel braided. Steel braided always burns you, and forget about that one piece sticking out that bites your hand. XRP you can actually touch the hose after a run and not burn yourself. So to me that makes your fuel even cooler.
Just my .02¢ Hope this helps.
