Tunned Port Injection?
Yep. no problem at all. Just make sure the base of the intake mathes the heads.......ie center bolt or perimeter. Most aftermarket bases now have provisions for both.
Chris
Also if the injectors are for the 305 you'll want to add (or make) an adjustable fuel pressure regulator so you can turn up the FP to make em work on the larger cube engine....
