what size injectors for 440rwhp?
Old 03-30-2005, 03:46 PM
silverbeast's Avatar
Default what size injectors for 440rwhp?
Hey Guys,
I have a set of TEA heads and a FMS f13. I am hoping for 440 rwhp and i was wondering what injector will be best for my application. My other mods are in my sig and i dynoed 351 rwhp and 367 rwtq so i think a 90 hp gain w/ heads and cam is not out of the question. Thanks for the help guys.
Old 03-31-2005, 09:15 AM
LS69TA's Avatar
TTT for ya. I'm wondering the same thing.
Old 03-31-2005, 12:05 PM
Thanks, I've heard of some people needing bigger injectors w/ a head and cam swap and some people are ok so im a little concerned.I just think with the combo ive picked out and my current hp that 440 is within reason. Thanks for the bump.
Old 04-02-2005, 07:48 PM
f-bodman's Avatar
You have an '02 so it came with the 28 lb injectors, I was told by Futral that my stock injectors would be fine with a F13 and my PRC stg 2.5's. I'm hoping for around 440 rwhp too, hopefully I'll be able to tell you if the stockers are enough injector here in a couple weeks.
Old 04-02-2005, 08:36 PM
Silver02's Avatar
I'm having a slightly more powerful cam, electric water pump and 3200 Yank converter installed. Also getting Accel 32 lb fuel injectors. Should these flow much more than the Z06 injectors I have now?
Old 04-02-2005, 09:58 PM
Thanks for the help. I hope they are enough but i may buy some bigger ones anyway because i will be spraying a little later on.
Old 04-02-2005, 11:41 PM
2000 Tran Zam's Avatar
from what i hear, the 2000 that has 26#ers are good to about 440 or so, approx. the 28#ers are good to 475 rwhp. so hopefully that will answer some questions. good luck.
Old 04-03-2005, 02:48 PM
Thanks, I hope so.
Old 04-04-2005, 10:27 PM
Mike @ New Era's Avatar
If that does not suport your HP , go with the SVO Bosch #30's , that will work perfect and you will not have to wrry about maxing them out . We have them in stock for $229 if you decide you need them .
Old 04-05-2005, 12:07 AM
pkincy's Avatar
Originally Posted by silverbeast
Hey Guys,
Assuming a BSFC of 0.5 The Lucas 42s are good for 629 crank hp, the 3 bar 36s are good for 532, and the 3 bar 30s are good for 443 crank hp. All this is at 80% duty cycle.
I went with the 42s since they have a rep of being ez to tune at idle (and they are) and would give me plenty of room up top (so far I have not seen any thing higher than 67% duty cycle and it idles well.
Based on this data the SVO 30s (32 at a 3 bar rating pressure) would be a fair bit too small. Of course if you miss your target rwhp, they may be fine. Or if you are willing to take a chance on them getting up to 100% duty cycle they also may be fine.
Old 04-05-2005, 04:04 PM
yak
yak's Avatar
I thougt only 98's had the 28's??
Old 04-05-2005, 04:50 PM
JoSeY's Avatar
I held 440rwhp @ MTI on Stock 99' 27lb injectors...stock pump also...+ 100 wet shot on top of that occassionally.
Old 04-05-2005, 05:08 PM
Viper's Avatar
JoseY
They are 26lb for 99 - even more impressive you did that!
Old 04-06-2005, 02:00 AM
pkincy's Avatar
I'll bet you love to play Russian Roulette with 2 chambers loaded also, correct?
Perry
Old 04-06-2005, 10:20 AM
Hotrod God's Avatar
I went with FAST 36# injectors when I put the new FAST 90mm TB and LSX intake on, along with a set of AFR 205's and Comp 228/230 cam. Probably is over kill for now, but I will be adding an aftercooled procharger sooner or later (when the $$ gets saved up).
Old 04-06-2005, 10:00 PM
Keenov's Avatar
98, 01-02 = 28#
99-00 = 26#
Old 04-07-2005, 09:45 PM
prostock_bigblock's Avatar
one word pal and i am sure about it :
you would need a 32 lb\hr ..........with no doubt.
Old 04-07-2005, 11:38 PM
WS6FirebirdTA00's Avatar
yeah you only want to run 80% duty cycle. like stated the 99-2000 are 26.4# and the 98,01-02 are 28.8# they dont flow enough for good power at 80% duty cycle. remember the hp ratings are crank not rear wheel. i figured one time i needed 34# injectors to support 430-450 rwhp. go with the gm 36# injectors and you will be set. i went with 38# racetronix ones and they are a bitch to tune, you have to adjsut the pulse widths and all that bs. stick with something easy to tune and that will support the power. 36#ers is my recommendation and then that give you room to grow. a good tune with the f13 could make a lot of power
Old 04-07-2005, 11:51 PM
prostock was right, 32# injectors should be good, but the 36 would leave some room
http://www.rceng.com/technical.htm
Old 04-08-2005, 04:08 PM
NastySSoo's Avatar
I ran stock 2000s on my 416 h/c car for 45k and countless passes at the track with no issues. Im putting gm 28 lbers in my new setup.
Paul
