How to Install Fuel Pressure Sender, PIC
I started putting in my gauges today and immediatly ran into a problem. I thought the sender that I would get with the Autometer gauge would screw right onto to fuel rail. Well the threads are different, one looks standard and the other metric, or standard and fine thread, and both end are male. Does anyone know where to get an adapter to put the sender on? I was just going to remove the bike tire fitting thing inside the rail, the put the sender on the end of the rail using an adapter. Does this sound okay? Has anyone done this before? Here is a pic of what I am talking about.
Thanks!
Thanks!
I did some searching and found this:
Is this what I want? I cant find any info on it except Speed inc says this: "Used with a fuel pressure gauge, will allow service to the fuel rail without disconnecting the gauge. A MUST if you drain your tank at the track for adding of racing fuel. Makes life so much easier!"
The fitting appears to be a 4AN on all three ends, with a schrader on the T, which means it won't work. Anyone have this fitting and can tell me what size the threads are. Thanks
Originally Posted by 99Ws6TransAm
its an npt fitting..you need a female adapter with an npt fitting for the sending unit.
Originally Posted by kjmdrumz3
Ok, but where is the adapter? lol. Maybe I'm just too tired to figure it out?
http://metco-inc.com/fuel/fuelgagedmt.shtml
