question about duty cycle.
, unlocked converter, but my stock injectors were at 100% duty cycle at wot at 5600 rpms and above. I upgraded to 30 lb injectors and the duty cycle dropped to around 80%. So I guess I ran out of injector, but why at such a low hp figure? I know that autos dyno higher with the converter locked, and the shop told me that dynojets dyno about 10% higher so does that mean I may have 400 rwhp on a dynojet with a locked converter? duty cycle DOES rise with hp right?
, unlocked converter, but my stock injectors were at 100% duty cycle at wot at 5600 rpms and above. I upgraded to 30 lb injectors and the duty cycle dropped to around 80%. So I guess I ran out of injector, but why at such a low hp figure? I know that autos dyno higher with the converter locked, and the shop told me that dynojets dyno about 10% higher so does that mean I may have 400 rwhp on a dynojet with a locked converter? duty cycle DOES rise with hp right?moving some serious air. Have you checked fuel pressure after 30svo's?
It proves that Stock injectors are inadequate. How did car run after the in-
jector change? You should be able to tell the difference.
w/30#svo's are pretty close to 80%. Mine's a m6 and I'm over the 400hp so
should be no problem w/yours.
i know iknow. but anyway, they told me the correct number, had it been run in 3rd, was 374 rwhp. 30 lb injectors will be good for awhile i suppose. i got up to 109% DC on stock 99 injectors on a really minimal setup, now i'm up to 85% DC on svo30s with 363rwhp
I'm getting ready to to hook up an air to fuel gauge and find out exactly what I'm running. On the dyno i was going from 13.4:1 to 12.1:1 at high rpm..that has changed now..I'm running about a 13.0 at high rpm
I have 32lb/hr injectors sittin in the garage waitin to be installed and i'm not going to get those in until i do a cam swap
