Racetronix Questions, Quick please
I have the racetronix plug and play kit and have a question. I have directions for the in tank stuff, but nothing for the wires and relay connected to the alternator. Can I hook the stock wiring up to the top of the fuel module? It seems it would be ok since a lot of people just drop the pump in and use the stock wires. I want to put the tank back in the car and finish up. If you can help, let me know.
Thanks,
Craig.
Thanks,
Craig.
I'd love to use the plug and play wiring, but I'm not sure exactly how to wire it up, here's a pic. See if you can tell me where or how these conectors hook up.
I was in the same spot you where. I was like where are the directions for the harness. I didn't even have any
..... Somewhere down the line I was sent the wrong harness for the 98 car so I was really confused. Would be nice if they would of had at least a footnote in there on what to do with the harness.
Ah, well all is well now.
..... Somewhere down the line I was sent the wrong harness for the 98 car so I was really confused. Would be nice if they would of had at least a footnote in there on what to do with the harness. Ah, well all is well now.
Originally Posted by speedo
... Would be nice if they would of had at least a footnote in there on what to do with the harness.
Yeah, it would have been nice to have known for sure what to do. I would have been pissed if I had to drop the tank again. I don't know about you guys but I had hell with getting the fill neck back on the tank.
One of the connectors plugs into the top of the pump, and the other goes to the stock connector that used to plug into the top of the pump. Then mount the relay somewhere, and hook the long wire up to the alternator.
