What fuel setup to use for ~800hp
Old 06-24-2005 | 12:42 PM
blown98z28!!'s Avatar
Default What fuel setup to use for ~800hp
What fuel setup would you go with if you are looking to make ~800hp with a single turbo. Thanks
Old 06-24-2005 | 01:43 PM
gator's 99TA's Avatar
aeromotive eliminator pump. sumped tank, 96lbs seimen injectors, etc etc
Old 06-25-2005 | 07:51 AM
BTL FED's Avatar
I like weldon pumps alot, I am running a weldon 2345
D2345
Weldon Pump is introducing a new quieter, lower speed, long lived fuel pump that will support 2500 HP at 70 PSI
http://www.weldonracing.com/d2345.html
Old 07-06-2005 | 06:27 AM
What is the advantage of using a sumped tank? How much can the stock fuel lines and rails support? What is limiting them? Where do you get the weldon pump?
Old 07-06-2005 | 08:05 AM
sb427f-car's Avatar
SSU'S Vice Mod
Biggest advantage is that you can use an external pump. If that sucker goes bad, no droping the tank to get to it. Also, it has the baffel to make sure you get a full, constant, and consistent fuel supply.
Old 07-06-2005 | 10:27 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
My setup for 754rwhp
Speed Inc. fuel rails
83 lb Siemens injectors
-10 line to front, -6 return
Speed Inc. drag tank
Speed Inc. twin Bosch 420 pump setup
Weldon regulator
You can run one pump, I used to run a Weldon 2025 pump, but you could hear it a block away.
Old 07-06-2005 | 12:17 PM
Thanks for the responses. How much can the stock fuel lines and rails support? What is limiting them?
Old 07-11-2005 | 08:20 AM
Wet 1's Avatar
ttt...
Old 07-12-2005 | 11:44 AM
MIGHTYMOUSE's Avatar
sounds like overkill to me
twin walbros
speed inc rails
russel -8 feed line
speed inc regulator
stock feed line for return
Old 07-12-2005 | 12:02 PM
twin walbros
speed inc rails
russel -8 feed line
speed inc regulator
What size walbros? 255s? Is there a write up somewhere about how to put together this whole setup? Thanks
Old 07-12-2005 | 05:38 PM
yes the model is gss340
i've written about it maybe a dozen times it seems... its in here somewhere
Old 07-14-2005 | 09:05 PM
mightymouse, what size fittings did you get with your regulator? -8? Also what fuel filter are you running? Thanks
Old 07-14-2005 | 10:04 PM
i got -6 with the regulator, but recently a guy in our car club got -8 which is kinda silly for it being on the return side, so i gave him the extra -6 i had.
i run that big aluminum case filter that speed inc sells.. all star or something like that? has -8 male on each end. also have the stock filter in the return line. and the filters on the pumps in the tank
Old 07-14-2005 | 10:39 PM
awsome, thanks a lot
Old 07-14-2005 | 10:43 PM
mightmouse, are all of the need attachments for connecting the fuel rails to the -8 fuel line included in the fuel rail installation kit?
Old 07-15-2005 | 11:05 AM
Nasty N8's Avatar
Nasty sumped tank, Billet rails and a complete fuel system using Weldon pump. E-mail me for pricing and a complete list. The stock rails and lines are barley good for 650-700rwhp any more than that and you are looking for trouble.
Nate
Old 07-17-2005 | 02:44 PM
69firebird's Avatar
MM,
are you using twin 255 or twin 340?
Old 07-17-2005 | 08:54 PM
twin walbro gss340's which are 255lph high pressure.
Old 07-17-2005 | 09:02 PM
69firebird's Avatar
awsome, thats great news for me, as that is the same setup i have.
thanks for the responce
ed
Old 07-19-2005 | 09:20 AM
LS1Tech Co-Founder
I would not skimp on fuel system, it's the most important part of an FI setup.
Reason to go with aftermarket rails, is that you would otherwise have to find someone who could attach a -8 or -10 fitting to the stock rails... Which is a waste of time.
Quick Reply: What fuel setup to use for ~800hp
