Locking Gas Cap
Old Aug 14, 2005 | 08:03 PM
Billy_B4C's Avatar
Question Locking Gas Cap
I dunno if this is in the right forum, but does anyone know the CORRECT locking gas cap for a 98 Z28?! I can't find one that will fit to save my life!
Old Aug 14, 2005 | 08:07 PM
CrawlinWS6's Avatar
Import Patrol
one does not really need locking gas caps anymore. The cars today are not like the older style where on can put a hose down your filler tube and suck gas out, unless you have *** that are putting crap in your gas tank.
Old Aug 14, 2005 | 08:16 PM
Billy_B4C's Avatar
I thought so. Thanks for the reply
Old Aug 14, 2005 | 08:20 PM
kp's Avatar
kp
I bought one from autozone for like 6.00, it didnt fit, the little triangle shaped lugs that engage in the two slots in the neck are just a tiny bit large. 2 minutes with a dremel fixed that.
Old Aug 14, 2005 | 08:42 PM
Ferocity02's Avatar
I went to Autozone and asked for a locking gas cap for a 99 Camaro. I paid however much it was, maybe like $10, and it fits and works perfect. Very good investment.
Old Aug 16, 2005 | 12:56 PM
SMOKINV8's Avatar
I'm curious to hear why they can't. I siphoned the gas out of my tank before I swapped fuel pumps. 98 Camaro here.
Old Aug 18, 2005 | 09:19 AM
LS1FIRE's Avatar
The 98 Filler necks are differnt from other years. I tried moding a couple of gas caps.I modded a Stant gas cap but the plastic is weak.The best one to run on a 98 is ACDELCO part# 22660006. There are triangle tabs on them all you gota do is file down our use a dermal tool to cut the tabs slightly for it to fit. And it will work perfect.
Old Jan 1, 2014 | 10:18 PM
calgary_z28's Avatar
Motorad MGC804 locking gas cap (Canadian Tire) also worked perfectly on my 98 after I followed your filing tips
