Installing Racetronix Kit
Old Oct 7, 2005 | 12:12 PM
99blancoSS's Avatar
Originally Posted by Ed Blown Vert
Then why do you keep saying you tried to plug in into the firewall? Nothing plugs in there!
I never said firewall only you.
Old Oct 7, 2005 | 12:14 PM
Ed Blown Vert's Avatar
Originally Posted by 99blancoSS
The picture they show of the 99 on the website, when the mech looked after finding it was the wrong plug, is actualy the correct plug for my car. It was like a 6 port plug. I recieve a twin plug. It was the wrong plug . It should have just connected the way it was supposed to on the backwall of the body above the axle where the old harness plugs into. The fargon installation was done right the plug was wrong!!
Here is one time you mentioned the backwall.
Old Oct 7, 2005 | 12:15 PM
Top of the tank but there is also a connection on the body behind the tank above the axle. This is where the plug was incorrect. Honestly its an easy install, there was no reason for any trouble, other than a wrong plug!
And another time you mentioned it.
Old Oct 7, 2005 | 12:17 PM
99blancoSS's Avatar
This is not the firewall. This is the back of the car. It was the only place the thing plugs into. It wasnt rocket science just a wrong plug.
Old Oct 7, 2005 | 12:22 PM
99blancoSS's Avatar
Backwall is not FIREWALL!! Ed your either yanking my chian or just dont see what I'm saying here, either way the plug was wrong and racetonix isnt doing anything except to deny. **** poor business if you ask me.
Old Oct 7, 2005 | 12:24 PM
Where did you try to plug the harness into?
Old Oct 7, 2005 | 12:26 PM
Either way, nothing goes there. Only on top of the tank.
99blancoSS's Avatar
There is only one plug with the harness and it only goes in one spot. It was the wrong plug. I'm done, if you cant understand argue with yourself some more.
Old Oct 7, 2005 | 12:28 PM
I think the problem is YOU don't understand. The harness only plugs into the plugs on the top of the tank. No where else.
It doesn't plug into the back wall. What part don't you understand?
I just installed mine so I know how it goes.
Old Oct 7, 2005 | 12:36 PM
99blancoSS's Avatar
Do you have a plastic tank? Its a different kit. The plug was wrong. The plug was meant to go somewhere and where it was meant to go it didnt fit because it was wrong. I cant make it anymore clearer than that. The 99 pnp harness for the plastic tank was a new product when I bought it as well, maybe it was packaged wrong at the factory?!? There are two different kits for a plastic tank and the metal tank. No one will say that though. I'll wait for your answer Ed .. metal or plastic? 99's had both in them
Old Oct 7, 2005 | 12:46 PM
I have a plastic tank just like you. I even have a 99.
I still don't understand where you tried to plug it in. You never exactly say where. On the back wall or top of the tank?? I am assuming you tried to plug it into the back wall.
Old Oct 7, 2005 | 12:49 PM
  #32
99blancoSS's Avatar
did your cable come with a weatherpak plug on it? Where the weatherpak plugs into is what I'm talking about. There's only one. The cable was meant to work and run in one direction, it wasnt the mechanic not knowing what he was doing it was a wrong plug on the end of the cable. How can I make it any more clearer? The thing plugs together, it's PNP if the plug ends match. The pictures on the website and the instructions were all the same except the plug on the end of the cable was incorrect. Yours obviously wasnt.
Old Oct 7, 2005 | 01:00 PM
  #33
This is how my harness looks.
http://www.racetronix.com/product/RX...99-FPWHG-2.jpg
Old Oct 7, 2005 | 01:33 PM
  #34
99blancoSS's Avatar
Thats not what mine looked like. The end with the factory plugs into here stuff was different. Thats what I'm saying it was wrong. Ed you get the picture now?
Old Oct 7, 2005 | 02:06 PM
  #35
Now it makes more sense. If you never referred to the back wall it would have made more sense sooner. I thought you were trying to plug it in there.
Is it possible they sent you the 98 version?
Old Oct 7, 2005 | 02:13 PM
  #36
99blancoSS's Avatar
According to them no. They never make a mistake but yet here we are.
Old Oct 8, 2005 | 02:05 PM
  #37
MasterMind's Avatar
Mine plugged in just fine, ran the wires to the alternator, great setup.
Old Oct 8, 2005 | 03:53 PM
  #38
code4's Avatar
Mine too, easy install/works great.
Old Oct 8, 2005 | 04:07 PM
  #39
Redneck Z's Avatar
Well....My harness at the top of the pump had the wiring backwards, so racetronix is human and do makes mistakes. So far they seem to be batting about 70%. Then again, the majority of people only post when something is wrong.
