best fuel system for 800 rwhp for FI?
Please help me with fueling concern.
I will be looking at making 700-900 rwhp through a 408, heads, and turbo. I have a Welbro 255 and wiring harness. I know this current setup will probably not be sufficient for my setup.
Money is getting short but I need to have a fuel setup that won't compromise my overall setup. Any way I could modify my current setup without going to a full scale race setup through Nasty, etc?
Any help would be appreciated!! Please remember I really am a newbie so more explanation than less is best.
Thanks!!!!!
Thanks!!!!!
I need turbo help from you!!!!
Thanks!!!!!
Thanks!!!!!
Mainly street some strip question-NEED HELP!!
Thanks!!!!!
Thanks!!!!!
twin 420s or a big single pump along w/ 60lb or 75lb injectors oughta do it. Hell just check out some of Speed Incs fuel systems http://www.ls1speed.com/catagory.cfm?catagory=Fuel / Cooling
Who makes the best fuel system for 800 rwhp for FI?
Who makes the best fuel system for 800+rwhp for a 2002 Z28, 408, heads, turbo, etc?
Thanks!!
Any advice would be appreciated. Who should I get this from, what should be included and how much $$$$ should this cost, etc?
Thanks!!!!!!!!!!!!!!
Thanks!!
We get alot of stuff from Nate at Nasty Performance.He can set you up with everything you need.Here is a pic of a system we just did for 800+rwhp
This was around $2600 I think.(didn't add it up)-aluminum fuel tank that has good clearance too.
closer to 3600 for everything... and yes its -8 -10 stuff
The tank is same as stock...15ish
i was actually wondering this same thing...
what all do you need for 800+ rwhp? fuel rails, pressure regulator etc?
sorry, hope i didn't hijack but i thought it was relevant...
I saw that speed inc. has a pretty nice looking fuel system setup.... anyone know anything about this?
i have also heard good things about aeromotive
The dual intank pumps have been ran in some 900 + rwhp cars and have proven to be a reliable and quiet setup. Nasty performance sells a nice little kit that includes everything from fittings to lines to fuel rails. The only things the kit doesn't provide is a proper intank hookup and instructions but other than that it's near perfect for me. What i did was i went to ACE and picked up some fittings and was able to come up with a nice way to connect the two pumps and get it out to the -8 an fitting that came with the kit. You also have the option of running 1 pump until the second is needed which is what i will be doing.
Greg
Greg
