Fuel pump problem?
Old Nov 12, 2005 | 12:57 PM
98silverSS's Avatar
Default Fuel pump problem?
My car has 97k on the clock and if i drive it for a long time, especially in stop and go traffic, there is a loud humming noise from the rear. i assume its the fuel pump. it is the stock unit. is it startin to crap out on me, should i worry about it?
Old Nov 12, 2005 | 04:09 PM
EPP's Avatar
EPP
I would replace it before you incur the expense of a tow truck bill. It sounds to me like it is on it's way out also. Bob
Old Nov 14, 2005 | 06:44 PM
flyin red TA's Avatar
I think mine is dying as well. 98 stock pump, 90k miles, with a walbro inline...it's loud as hell now. When I'm coasting around at low speed, the whine goes away, then the revs drop...it's bad enough that the car will die. Today it happened, and with the key in the run position, the pump wouldn't kick on so I couldn't start the car. After a few minutes I finally heard the pump kick on when I turned the key and the car started...I was shitting my pants thinking I was going to be stuck on the side of the road.
Anybody know what this would cost me to fix at the dealer?
Old Nov 14, 2005 | 11:54 PM
Matt@HSW's Avatar
Dealer = $$$$. I think it might be less expensive to pick up a Racetronix kit. They are pretty easy and straight forward to install, if you think you can do it you'll save a bit more there too.
Matt
Old Nov 15, 2005 | 05:03 AM
I just don't have the time to fix it myself...I'm either in school or at work. It'll end up sitting in my garage torn up for weeks.
Old Nov 15, 2005 | 05:07 AM
EPP's Avatar
EPP
We charge $300.00 labor to install a Walbro in tank pump, so you would have $455.00 total in replacing your stock or aftermarket pump with a Holley/Walbro pn#12-914 forced induction fuel pump. Bob
Old Nov 18, 2005 | 05:02 PM
Ended up taking it to the dealer...$85 diagnosis and a $10 fuel system relay and it's fixed.
Old Nov 23, 2005 | 10:19 AM
cantdrv65's Avatar
Post
To the orginal poster, yep your pump could quit at any time...They hum loud for a while then die without warning...
