Need Help!!
Old Dec 5, 2005 | 01:39 PM
lilicedout24's Avatar
Question Need Help!!
i have been getting head achs trying to figure out what size injectors to go with . set up so far keep in mind motor is not in car yet tb ported/tb enhancer/tr224 112 lsa cam/3200 stall/tci &md racing kits/msd wires/ngk plugs/255 lph fuel pump/ls6 intake on order/hedman headers/3in1 chamber flowmaster/dyno max custom bent pipe/whisper lid&K&N/ if any more step any one can come up with im all ears i want a bad *** street car nothing to do in new orleans but street raceing thankx for yall info
Old Dec 5, 2005 | 07:00 PM
onfire's Avatar
Coal Mining Director
That's easy SVO 42lbs...easy to tune..plenty of room to add power later.
Old Dec 8, 2005 | 12:59 PM
ok so i will need to custom tune to use 42 right?heads are also stock
Old Dec 8, 2005 | 01:50 PM
bshell's Avatar
Any injector with a fuel delivery rate different than the stock injectors will require tuning. Good luck with your new motor!
Old Dec 8, 2005 | 03:38 PM
ok thankx just don't wanna go to big not getting tuning till after i buy injectors just need a good size for all around use
Old Dec 8, 2005 | 04:24 PM
Nasty N8's Avatar
Stock injectors are more than sufficent for your setup. 98 injectors are 28lbs
Nate
Old Dec 8, 2005 | 08:37 PM
Nate
ok so i have ls6 intake came with injectors on it what are they or put my 98 injectors back on?
Old Dec 8, 2005 | 10:05 PM
SRPerformance's Avatar
28lb injector can flow 360rwhp but at 100% duty. See thread for change to 36lb
https://ls1tech.com/forums/fueling-injection/417995-new-injectors.html
Rgds
Old Dec 9, 2005 | 12:33 AM
SlpLS1's Avatar
42 lb'rs sounds good
Old Dec 9, 2005 | 09:57 AM
618HAWK's Avatar
Go with the 42#s and you will be set. Easy to tune for and will leave you with plenty for down the road. You know the mods are not going to stop, theres allways somthing else
Old Dec 9, 2005 | 04:01 PM
ok so where can i get the 42 any name brand suggested this should be the final ?
Old Dec 9, 2005 | 07:49 PM
618HAWK's Avatar
I bought mine from Bob @ EPP http://www.exoticperformanceplus.com/
Great guy with good price, he can set you up with most anything 260-483-9300.
As for brand went with the standard SVO 42#s
