Fast fuel rail pics.
Old Feb 17, 2006 | 12:07 PM
Nasty N8's Avatar
Yes
Nate
Old Feb 18, 2006 | 12:05 AM
96silverram's Avatar
Nate, Do you guys have any nice fuel rails like the ones in the pic for a LT1 ??
Old Feb 18, 2006 | 12:27 AM
obZidian's Avatar
NO!! No rails for the lt1..now go away before i turn you into, into....a, into a newt!!
"A newt?"
"yes, A newt! Now, shoo, shoo!"
Old Feb 18, 2006 | 12:51 AM
speedo's Avatar
Ok, I have been looking to getting a set of rails down the road also. Nice looking setup with the gauge......
Now where does the regulator get put in between the supply and the rail? What kind of regulator is used Is it just easier to buy the rail supply kit from Seedinc for 99$
Old Feb 18, 2006 | 09:17 AM
obZidian's Avatar
normally, the regulator is put on the return side. Basically, instead of have that gauge or a plug on the pass side, you would have an hose leading into a regulator, that regulator would or could be hooked up to a gauge, while the hose leading out of the regulator will be your new return line back to your tank.
These cars have a return but it is hooked up all the way in the back by the fuel filter... just run the line to a y-block that is there and shazam!!!! You got regulation...
I belive you might have to remove your stock regulator that is you tank in order to have an aftermarket regulator installed....
good luck..they sure look nie in person...will have some picks up...
laterZ!
