My racetronics pump whines alot louder now. Is that normal?
I had 1/2 a tank of gas and I also filled up the resevor bucket befor I powered it up. I then turned the key on a couple of times before I started the car for the first time to help get the gas purged into the pump. I also did not start the car for a couple of days after installation of the pump so I though that I did everything right. My pump was quiet also at first but for the last couple hundred miles it's been louder. I have about 1000 miles on the pump also. fuel pressure seems to be fine at 62 PSI and 58 PSI at WOT.
Originally Posted by 618HAWK
No Mine is quite as well...How much fuel was in the tank 1st time you put power to it. I read somewhere that Racetronics say to have at lease 1/4 tank prior to putting the power to it. And never test it dry-out of the tank.
Are you having any pressure problems?
I used the trap door methode, I shined alight into the tank and the tank was way clean, I also ran water over the top of the gas tank to get rid of all the cutting dust and dirt.The top of the tank was clean and dry before I started my work.
I hate to say it but, there might have been something in the tank that made its way to the pump. When I replaced mine I dropped the tank and did a full clean and flush job. Then wiped out the entire inside with a tack rag followed by a white cotton rag just to make sure.
