boost reference on the FPR
Old Mar 30, 2006 | 01:28 PM
ty_ty13's Avatar
7 Second Club
Default boost reference on the FPR
on the FPR there are the boost reference ports, where are you guys bringing this line from? what is it coming off of?
thanks,
Tyler
Old Mar 30, 2006 | 01:40 PM
MECHAM's Avatar
tap into the line that goes behind the manifold
Old Mar 30, 2006 | 01:42 PM
ty_ty13's Avatar
7 Second Club
the map?
how do you tap into it... sorry for being a newb
Old Mar 30, 2006 | 01:49 PM
ddnspider's Avatar
tap into the large hose off the back of the intake is what Mecham meant,its the brake booster
Old Mar 30, 2006 | 01:54 PM
MECHAM's Avatar
sry man...i hate it when people are non - descriptive...so here is a photo
Old Mar 30, 2006 | 01:59 PM
ty_ty13's Avatar
7 Second Club
awesome... after he said brake booster line i new what he ment...
how are you guys doing this? what are you using?
sorry im very noobie to FI
Old Mar 30, 2006 | 02:26 PM
MECHAM's Avatar
essential..u will cut the brake booster line in half...after the clip..and few inches cut it...then you will insert one of these metal pieces like below to reconnect the brake booster hose u just cut and it supply a nipple for your FPR
i have no idea where to obtain this fitting...
Old Mar 30, 2006 | 03:14 PM
ty_ty13's Avatar
7 Second Club
im very grateful.... your one of the few who will go out of their way to help.
Thanks,
Tyler
Old Mar 30, 2006 | 03:27 PM
onfire's Avatar
Coal Mining Director
I wouldn't do that...it also refs vac. Tap a fmpr before the throttle body. That way you can set the base pressure at 58psi and it will only ramp up 1:1 with boost.
Old Mar 30, 2006 | 03:37 PM
ty_ty13's Avatar
7 Second Club
what is fmpr
and how do you do that?
Old Mar 30, 2006 | 04:41 PM
ABeasst's Avatar
fmpr= fuel pressure regulator
Old Mar 30, 2006 | 04:54 PM
ty_ty13's Avatar
7 Second Club
he said to tap it before the TB.... where or what hose is that?
Old Mar 30, 2006 | 04:58 PM
ddnspider's Avatar
actually if you used a check valve than it would work....but ive never heard of fuel pressure dropping because vacuum was going to the FPR.i didnt think that was possible
Old Mar 30, 2006 | 05:00 PM
ty_ty13's Avatar
7 Second Club
is a check valve just a one way air passage?
Old Mar 30, 2006 | 05:01 PM
ddnspider's Avatar
you got it.but id double check about the FPR first because ive never heard of the pressure dropping simply because of vacuum
Old Mar 30, 2006 | 07:24 PM
onfire's Avatar
One way check would work great. Some Front Mount Fuel Pressure Regulators do reduce fuel pressure based on vac...just like they ramp up fuel pressure based on pressure.
I tapped my inlet pipe before the throttle body and took that reference to the regulator.
Old Mar 30, 2006 | 08:37 PM
MECHAM's Avatar
pic?
Old Mar 30, 2006 | 10:24 PM
onfire's Avatar
This will get ya close. You see where the line leaves the Wedon regulator and travels between the fender and the abs block. Then it leaves the pic and turns into the black pipe that has a barbed nipple....so boost only reference.
Old Mar 30, 2006 | 10:29 PM
ABeasst's Avatar
onfire what is running off the power steering pulley?
Old Mar 31, 2006 | 08:21 AM
onfire's Avatar
Scavenge pump for the turbos.
