Nasty fuel system install pics
I know some haven't had to do that from the look of the pics but I realize every car is slightly different and my tank might not fit the exact way it does on all cars....
So far I am VERY impressed with the fit and finish of the Nasty Performance stuff. Nate has been very helpful throughout and although a tight fit you can see the R&D that goes into this tank. without the pump and the filters on the side you could probably toss this thing a quarter mile cuz it's THAT light.... So if you buy one of these tanks you probably need 10mmx1.5x100mm bolts.... Those are what I used.... you might get away with shorter ones depending on your straps. And I highly recommend pre bending the straps using a vise beforehand that way they lay down and angle where the tank angles (cause the stock tank is rounded....) enjoy!
Are ya sure those are the right fittings? Did you talk to Nate before cutting into the car to make sure?
I know I wouldn't go with the setup if I knew I had to hack into the car to make it work...
http://community.webshots.com/photo/...54690673EOSnix
Yeah I plan on cutting the feed line down a bit so it'll be closer to the body but I have to see how much I can turn the fitting on the sump.... The clearance is still tight and might not warrant pointing more level to the body...
Nate
Me having to clearance the trunk area was not a big deal to me. I don't drive the car in the rain. it is NOT my daily driver and I've seen others have to do ALOT more clearancing than this to fit things they want in their car (IE cutting the cowl to clear Single Plane manifold and TB Elbows, cutting holes to run intercooler piping in the firewall, and even cutting holes in the hood to clear turbos or high manifolds.... This was NOT a big deal and certainly no fault of your design.... I look at it this way. Now I have an area I can run wires/lines/etc thru without having to grommet every single hole...
No the stock straps don't need to be extended they just need to be molded on a vise so they are straight and follow the angle of the tank. best way to do it is lay the strap down after you've completely straightened it and mark where it needs to bend. then put it back in the vise and make the bends. the stock tank is rounded and you'll be way short if you just put them back up there the way they were with the stocker...
If you use 10mmx1.5x100mm bolts you'll have plenty of threads to get them to torque down into the brackets up above....
why couldnt you use a tighter elbow?
heck i would of bashed the area in with a hammer before doing that.
nice looking tank thou.
