1500+ hp worth of fuel system
I am having a huge problem choosing what to do with my fuel system. Here is what I am trying to achieve:
1. 1500+ crank hp worth of fuel
2. Would like to run a pump or pumps that can be mounted in a tank.
3. More then likely I will be building a tank that will go in stock location, will have room for pump/pumps inside, and have room for a overhead antiroll bar.
At the motor I have big diameter rails, feed will come into the back of the rails(via a y block or 1 line from each pump) front of the rails will return through the 2000 series aeromotive afpr.
I am trying to build a stock appearing fuel system that fills like stock, that isnt loud, and supports big hp. Any suggestions on pumps? Ideas?
I don't think there are intank pumps that can suport that power. But a Weldon wouls do that easy. I would y-block into the rails too. I was told my system wouls handle 1000hp FI. Weldo 2015 rails y block ect...
