need fuel pump... which one?!?!
Old May 18, 2006 | 12:25 AM
NBMgreg's Avatar
Default need fuel pump... which one?!?!
so my fuel pump went out today... trying to see how far i could go on E...
anyways, i was told to look into a walbro 255lph fuel pump, but which one do i need? in-tank? is it a direct swap? any info is appreciated.
Old May 18, 2006 | 12:50 AM
NBMgreg's Avatar
also, if i were to go with a walbro 255lph fuel pump, would my gas milage be affected by switching to that over a OEM replacement? my car doesnt have many mods, so i dont need anything extreme, just something that will be better than OEM, without sacrificing gas milage or anything.
Old May 18, 2006 | 07:41 AM
Michael02hawk's Avatar
Racetronix intank fuel pump.
...and while your in there, dont forget to upgrade the wiring too.
Racetronix includes the plug&plug wiring harness upgrade, or get the hot-wire upgrade if going with walbro or another pump.
Old May 18, 2006 | 07:51 AM
227Hawk's Avatar
Another vote for Racetronix
Hawk
Old May 18, 2006 | 08:26 AM
Matt@HSW's Avatar
Hard to beat the Racetronix kits. They come with everything you need and are pretty easy to install. LINK for more info.
Matt
Old May 18, 2006 | 01:56 PM
NBMgreg's Avatar
would the racetronix be adequite for daily driving? would it affect MPG at all?
Old May 18, 2006 | 04:46 PM
Matt@HSW's Avatar
Yup, it would be fine for daily driving. Shouldn't affect your milage any too.
Thanks,
Matt
Old May 18, 2006 | 08:45 PM
SVC707's Avatar
how much power can the racetronix support. im looking at possibly over 700 rwhp with my setup when its done
Old May 18, 2006 | 08:48 PM
NBMgreg's Avatar
i went ahead and ordered the racetronix kit this morning, will be here tomorrow.
it can hold whatever a walbro 255 can plus more, due to the upgraded harness. i believe the 255 is good for 700-800rwhp.
Old May 18, 2006 | 09:23 PM
227Hawk's Avatar
With a supercharger the 42-60 # injectors will be looking for fuel.
Check with Nasty Performance - Sponsor ( Nate) for your fuel needs.
Hawk
Old May 19, 2006 | 08:09 AM
Matt@HSW's Avatar
+/- 600 rwhp. +/- 650 rwhp with fuel rail mounted fuel pressure regulator & return line. A BAP can be used to push it a little more.
Matt
Old May 19, 2006 | 08:42 AM
SVC707's Avatar
so this wont work then as i dont want to being pushing the limits. i would rather have room to spare. thanks for the info
Old May 23, 2006 | 01:29 AM
9formula4's Avatar
kind of coming back form the dead but my fuel pump took a **** on me also and looking at this everyone is kind of contradicting themselves. They say walbro sux but the racetronix IS walbro it even states it in there ad.
Old May 23, 2006 | 05:03 AM
JMBLOWNWS6's Avatar
Modified Walbro's Trust me there different. Jack can explain more.
Old May 23, 2006 | 11:58 AM
NBMgreg's Avatar
i was in your same situation, i ordered the racetronix last thursday, and did the swap 2 days ago.. i went ahead and dropped the tank, and that was a royal PITA, on the 98's the filler tube is permanently attached to the tank, so its kind of like doing headers, there is only 1 way that it comes out, and it can take forever to find that one day to get it out of there... very frustrating. after that the pump went in easily, the harness was easy, very straight forward, and a good quality kit i must say.
on the initial start up, it started right up fine, no hesistation whatsoever, i had alittle less than a quarter tank, so i drove carefully to the gas station, but one thing i noticed was when i took off out of my neighborhood it kind of stuttered alittle in 1st, not sure if was the level of gas, or just because the pump is brand new and what not, but i went and put 10 gallons in like they suggest, and it works fine, it is louder than stock, and you can hear it at a stoplight, but it doesnt bother me, i kinda like it lol.
my question is, what are the limits of this racetronix fuel pump? like, i use to run the stock one down to E, how far can this one go before i should fill up again?
Old May 23, 2006 | 12:16 PM
Nasty N8's Avatar
You can run it just like stock they sit in the same exact location.
Nate
