Low impedance LS1/LS7 fuel injector...
I need a low impedance fuel injector that will fit into a LS7 intake and a LS1/LS2 fuel rail cup... Anybody???.... 60lb, 72lb and a 92lb (I'm using a factory style LS1 fuel injector connector)
Thanks
Thanks
Originally Posted by sslow2000
im using a set of low impedence MSD 72#s... seem to be working good so far!
got them from the local speed shop...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Did you use a LS1/LS2 fuel rail with those injectors? They are pricy too. $90.00 each. I'm hoping I can find something cheaper...
Originally Posted by ZL1Killa
I'll call them on Monday... Thanks.
Will the Racetronix 75 lb/hr injectors, part number 3145 fit in the LS7 Intake using the Katech LS7 Intake fuel injector O-rings?... I think the fuel rail O-ring will fit OK in the LS1/LS2 fuel rail cup... Anybody?
Here is a link to the dimensions...
http://www.racetronix.com/images/inj...1dimension.gif
