gas gauge compatability
I just completed an LS1 swap into my 1984 Trans Am. The fuel gauge doesn't seem to work. The needle is way past the full mark and just sits there.
I was told this may not work, but I'd like to be able to have a working gas gauge.
Is there someone who can recalibrate/ rebuild it?
Would a later 3rd gen gas gauge work?
would a 4th gen gauge work (assuming it's an independant unit behind the dash panel and it can be relocated into the 3rd gen dash)
Or am I stuck buying a universal gas gauge?
Any help would be appreciated.
thanks,
-BV
Could a fuel gauge be taken form a 4th gen car, or is it one big integral unit in the cluster?
Best bet is to buy a programmable Autometer gauge. The 1999 and up GM senders are 33ohm empty, 250ohm full....I couldn't find an aftermarket gauge to hit those crazy numbers. Only bad thing is Autometer programmable is $109
LS1 fuel gauges go through the PCM, I assume you arent using the PCM for the gas gauge since its serial data on a 99+ I believe. Best solution IMO would be to keep the stock gauge would be either pop a hole in the tank for an aftermatket sender or try to get an aftermarket universal 0-90ohm sender mounted to the stock fuel module in the tank.
