Fuel pressure dropping under normal driving???
little background - c5 Corvette, Converted fuel system to the 97/8 with return on the rail, LPE 255lph Fuel pump, Adjustible regulator set at 58psi and boost referenced. Stock ATI kit - running 7-8psi, jsut over 500 rwhp. NO BAP.
ok, So - the car was running great with no fuel pressure issues for just about a YEAR on this setup - I DD this car, so it has been about 10k on the clock.
I already replaced the pump and i was seeing a drop in pressure at 2psi right around 3500 rpm, it would drop 10psi instantly if i jumped on it... I chalked it up to a bad pump and just put another one in with a new filter........SAME PROBLEM..... I still am DD'ing the car, and noticed that i dont even have to be in boost to loose pressure - right around 4-4.5k it will start gradually dropping pressure when under 10in of vaccum... there are only 42psi injectors in there, and the car is completly stock outside of the procharger - so without seeing any boost - how could i be loosing pressure? There shouldnt really be any much drawl on the pump.
I checked voltage (still running stock wiring) at the pump at idle and it is around 13v, dropping to 12.9-ish if i rev it up.
The car has been running fine for a year - so i dont really think it could be anything with the feed line or rail, but what else could it be? Maybe a weak altenator? It reads high 13's, low 14's at idle.
I have a 8 gauge wire already run from the battery to the pump area, just never hooked it up as the car was running fine - Not convinced that hooking this up will really do anything - as i have read that running the pump at a higher voltage will increase the heat in the fuel lines - being a DD and about an hour drive either way - i dont want to put any more stress on the pump then it already has.
Any ideas here? I am pulling my hair out - It cannot be the pump at this point.
Thanks!
Nate
I understand the higher voltage from the altenator will "boost" the pump a little, but this will also increase the heat generated by the pump (i imagine).... I will go this route if needed, but dont see how that would help this situation.
I would think that if the Y portion was blocked (going to the pass tank) that you would actually hold pressure better, as there would be NO loss of volume going to the pass pump.
I was thinking about that Y and wondering it that could be causing any issues... Did you just replace it or unclog it?
I have also been toying with the idea of moving the Y to the return side to power the pass pump..... so you would have all pressure going to the feed. just not sure if there is enough pressure to power it.
