Car wont start plz help urgent!
It involves the little tab thats on your key...That little pellet is a resistor that when inserted into the ignition it bridges the contact between 2 VERY small/delicate wires.This allows the VATS system to read the resistance of the pellet on the key and in turn gives the "go ahead" if the resistance is correct.
If the key is old and/or damaged,the system might be getting an incorrect resistance reading and ends up locking you out as if your using the incorrect key...
Try a spare key for the car if you have it.If its the key,the spare should work.Or you will have to get another key cut with the correct resistance pellet from your dealer.
Here is a link that may help out VATS info
If the problem is deeper in the system,its most likely the delicate wires which you can end up replacing the whole ignition cylinder(plus keys) or you can bypass it using a spare key or resistors from Radio Shack (or similar store) that add up to the same resistance level as your original key's pellet.All this info should turn up on searches,including how to tell what resistance level your key pellet is using an OHM meter...
Of course this is all just a possibility,check all the usual suspects of course and if you do any of this stuff with the VATS,do so at yur own risk!!!!!!LOL!
Nate
Nate
