Fuel systen upgrades??
Old Aug 28, 2006 | 04:59 PM
fastbasser's Avatar
Default Fuel systen upgrades??
How many HP can be supported by using a LPE in tank pump and a KB (or similar) Boost a pump?
Thanks in advance.
Old Aug 28, 2006 | 05:32 PM
99SS-T's Avatar
By LPE intank im assumin that u mean a 255 intank pump. With that and a BAP u should be able to support about 550-600 with good injectors like motron 60#er's. GL man
John
Old Aug 28, 2006 | 07:15 PM
fastbasser's Avatar
So we can safely assume a big time upgrade is needed if you are in the 750 range?
HMMMMM
Old Aug 28, 2006 | 09:32 PM
99SS-T's Avatar
Well not BIG time. Big time is 4k. U can get all u need for 750 rwhp for about 1500. LS1 speed and others have kits for these power levels that work great and dont make a **** ton of noise. GL man
John
Old Aug 29, 2006 | 04:01 AM
EPP's Avatar
EPP
Smile
HMMMMM
For 750 rwhp, you do need a dedicated fuel system. Larger fuel lines with a return fuel sytem, which requires a regulator, a larger fuel pump or pumps, and larger fuel rails. Bob
Old Aug 29, 2006 | 11:10 AM
Nasty N8's Avatar
Give us some more details on your setup and we can get you a better idea of what kinda fuel system you will be needing.
http://www.nastyperformance.com/FuelSystems.html
Nate
Old Aug 29, 2006 | 05:24 PM
fastbasser's Avatar
Looks like I'm installing a ECS Novi Kit on my 427.. Gonna have to drop the bucks on thier C5 Fuel system upgrade.
Guess there is no sense in trying to go w/o it.. Whats another few bucks!! Yeah right!!
Old Aug 30, 2006 | 10:10 PM
SVC707's Avatar
i went with the Nasty Performance setup.. just do right the first time... im not saying there arent any other options but you dont want to half *** fuel when your pushing high numbers is what they always say.
