what size injectors for my setup
Old Aug 29, 2006 | 04:53 PM
iwineng03ss's Avatar
Default what size injectors for my setup
whats up guys i have a stock set of injectors from when i switched out injectors on my truck. i starting to think maybe they wont be big enough. here is what i have in store for my build..
2002 ls1 with pro products intake mild port on the intake mild porting done to the throttle body, and heads comp cam .566/568 i will be spraying it probably 125-150 shot. i will also be using a walbro 255lph intake fuel pump. im pretty sure the stock injectors should be fine but i wana make sure before i get really moving on this thanks for any help you can give
Old Aug 29, 2006 | 11:17 PM
ZL1Killa's Avatar
i wouldn't think 125-150 shot w/stock injectors would work out too well, but i could be wrong(haven't played with nitrous) but i would def get 36#ers or higher for safety
Old Aug 29, 2006 | 11:38 PM
Ryan K's Avatar
Pathological Modifier
Are you planning a Dry nitrous kit or Wet? If its a Wet kit, they'll be fine. If its a dry system, I'd upgrade, but people have done it with out problems.
Ryan K.
Old Aug 29, 2006 | 11:50 PM
yes it is a wet system.. thanks for the replys guys.. i do plan on running a walbro 255 intake also so i thought i would be ok but i wanted to make sure..
Old Aug 29, 2006 | 11:57 PM
TransAm6383's Avatar
i have a set of 30# injectors ill sell ya..... pm me for more info
Old Aug 30, 2006 | 10:12 AM
i think my stockers are either 25 or 26#ers. im gonna see once its running what the lm1 says and go from there.. unless u guys honestly dont think the stockers will be enough
Old Aug 31, 2006 | 12:48 PM
2002SilverWS-6's Avatar
Default 30lb injectors
can I get a price? shipped to 15037
Old Aug 31, 2006 | 01:35 PM
98camaroLS1M6's Avatar
go with the racetronix Delphi/Lucas 37# injectors.
