450rwhp what size injectors?
Old 09-28-2006, 08:27 AM
stealth71's Avatar
Default 450rwhp what size injectors?
Will my stock '02 injectors hold up to 450rwhp NA? I plan on spraying down the road, but it will be a wet direct port kit. What is the cut off on stock injectors before the are maxed out? What size should I run if I need to change?
Old 09-28-2006, 12:21 PM
Sigforty's Avatar
I can tell you that my Z06 is at that hp level already and the stock injectors are at 105%. I think some 32 lb injectors would be a safer choice.
Old 09-28-2006, 12:58 PM
black01_WS6's Avatar
go with some 42's it gives you a little bit of breathing room for more mods.
Old 09-28-2006, 01:47 PM
stealth71's Avatar
Ok so I guess I need injectors too now. What about the folks that say let the tuner decide?
Any reccomendations on injectors?
Old 09-28-2006, 06:36 PM
Black Plague's Avatar
With a stout 450 hp get some MSD/Holley 50's or Motron 60's! They are a better injector compared to the disc style 42.5 009's! And of course see if your tuner can tune for them first! But I say go big and tune! Both of these injectors perform really well at low duty cycle.
Old 09-28-2006, 07:17 PM
BriancWS6's Avatar
I have the Racetronic 42 lbers, they are way more than I need on motor, but I got them to have room for the dry shot.
Old 09-28-2006, 08:24 PM
SS1875's Avatar
SVO 42# injectors here and currently 500+ HP NA. My tuner told me they are one of the easiest injectors to tune with.
Old 09-28-2006, 10:24 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Go straight to 60s because you never know what the future might bring.
Old 09-30-2006, 02:06 AM
formula305's Avatar
Im running red tops with 442rwhp and they are only at 82% duty cycle.
Old 09-30-2006, 03:54 AM
cantdrv65's Avatar
Post
Im running the SVO30's with 450+rwhp....about 80% duty max....
Old 09-30-2006, 01:30 PM
Old Geezer's Avatar
Question A bit of education..
please. How are you supporting approx 500FWHP, with a 30# inj, and only seeing 80% DC??
Old 10-09-2006, 02:14 PM
fastGBcamaro's Avatar
Default me to
Im running almost the same numbers with the same size injectors. I think a lot of people go way too big with injectors. I understand getting 42's if you are planning more modds or a dry shot of N2O. Also I believe that the SVO injectors are rated at a lower fuel psi than we use on our LSX vehicles so a SVO 30# injector is actually equivalent to a 32or 34 # injector on our cars.
Old 10-09-2006, 10:30 PM
2scoot's Avatar
A few others have said it....42's. Go too big and you have idle issues.
Old 10-09-2006, 10:55 PM
Asmodeus's Avatar
My GN has 72#'rs. Very very hard to get them to idle well on a batch fire DFI.
Old 10-10-2006, 12:18 AM
Mike @ New Era's Avatar
If you are at 450 whp , go #42's or at least #30's . #30's will max before 500 whp so at least with the #42's you will have some room . Lucas and SVO are the same to tune with , I have never noticed a difference in the LS1 on these at this flowrate .
Old 10-10-2006, 06:07 AM
brad8266's Avatar
Go with 42Lb'ers. They are cheap, work well, and can supply fuel for a lot of power.
Old 10-10-2006, 09:00 AM
stealth71's Avatar
Who has the best deal on a set of 42# quality injectors? I read some bad stuff about the racetronix disc style, should I avoid them?
Are these any good? http://cgi.ebay.com/ebaymotors/8-Bos...QQcmdZViewItem
Old 10-10-2006, 01:15 PM
SSilverSSurfer's Avatar
^^^like he said above, whats a good injector to go with?
Old 10-11-2006, 12:56 PM
slow trap's Avatar
i have the 42 lb delphi/lucas injectors and they have worked great for the few weeks i got to run them before i spun a bearing
Old 11-07-2006, 07:21 PM
Restricted User
98Z28CobraKiller's Avatar
I got my 60's idling good but I think that they are causing a very annoying surge in the 1800-2200 RPM at 3-6% Throttle position. I am trying to find someone to swap them for some 42 SVO's. Unless you are gonna go FI or a huge dryshot, you will not likely ever have a need for 60's.
Quick Reply: 450rwhp what size injectors?
