Fuel return line?
to make it work, you'll need to find a 97/98 vette fuel rail or some of the aftermarket companies can help you out with a fuel rail.
i just know this info b/c i'm swapping an ls6 intake on my truck soon.
I bought a set of billet fuel rails and made a complete return style system with a external pump and an Aeromotive regulator.
Or, you can do the 97-98 corvette stock fuel rails that has a return fitting on it.
Or, you can keep the factory rails and mount a return style fuel pressure regulator in line at the rear of the car. (near the tank) Setup is, fuel pump out to one side of reg and fuel to rails out the other side. Bottom return of reg back to tank. There is a long post on pro-touring.com in the fuel injection area just about this subject.
Hope this helps
Use the Russell adapter fitting for the rail to 6-an. Part #rus-640850 in other thread.
Nate
Probably would br cheaper overall to do the regulator in the back and aftermarket rails, Nothing wrong with the regulator in the rear if its not a high HP car.
