370 + t76 fueling
Old Oct 24, 2006 | 07:58 PM
mtb989s's Avatar
Default 370 + t76
I am putting a 370 with the 76mm t6 turbo. I plan on upgrading later to a larger turbo, but I am wondering how I will give it enough fuel.
I am going to have 2 walbro 255's. I know the stock pcm with HP tuners will support 65lb injectors but I don't think they will be enough in the long run. With the 76 I will have about 800 rwhp, but the 88mm will bump it to around a 1000. The problem I have ran into is the stock pcm not being able to support the 96 lb injectors that I will need for the larger turbo.
I want to know what I should do
-Buy 65lb injectors and stay at 800 hp with the 76
-go with an aftermarket system like big stuff III and 96 lb injectors
I don't want to spend the money on the big stuff right now, but I am going to put on the turbo. I need some advice. What are some of you budget guys doing??? I've heard of a MAF translator, would this work???
Thanks in Advance
Old Oct 24, 2006 | 08:06 PM
sb427f-car's Avatar
SSU'S Vice Mod
Thanks in Advance
The problem is the high impedance vs. lowimpedance injectors. Definately look to see what's out there as I don't think anyone is making a high Z injector in a 96# which means you'll be going to aftermarket to drive them, or maybe piggy backing with a megasquirt unit like Perish.
There is definately info in this forum as well as the fuel forum...try a search.
Old Oct 24, 2006 | 08:43 PM
Stupid Boost's Avatar
Which T76 are you going to be running that is T6??
Old Oct 24, 2006 | 09:17 PM
mtb989s's Avatar
it's a garrett with a larger housing. Should perform very well.
Old Oct 24, 2006 | 09:37 PM
caindo's Avatar
high 2 low converter box + 96s.
Old Oct 24, 2006 | 09:55 PM
SuperZ's Avatar
you know its a garret but you dont know anything about it??
Old Oct 24, 2006 | 10:32 PM
frcefed98's Avatar
Prolly talking about the same GT42-76 T6 flanged turbo you run.
I'd go with an S78 or S88 from forced inductions, be your best bet. www.forcedinductions.com
J
Old Oct 24, 2006 | 10:33 PM
FormulaFire's Avatar
Go Big or Go Home!
Old Oct 24, 2006 | 11:22 PM
mtb989s's Avatar
Ya that's the one. I just got it yesterday, so I don't know that much about it. The 76 I got for $300 so it will work for now, the 88 is around the corner. I just need to now a cost effective way to get enough fuel.
Thanks for the input.
Old Oct 24, 2006 | 11:29 PM
frcefed98's Avatar
Dual walbro 255lph pumps
-8an feedline or bigger
-6an return
Speed Inc or NastyN8 high flow fuel rails
Aermotive AFPR
60lb Mototron Hi impendance injectors....for now....converter box for bigger injectors for later. Y2Khawk makes one ...i think. PM kp here on the board and ask him where he found his old converter box.
J
Old Oct 24, 2006 | 11:56 PM
SuperZ's Avatar
J
Ahh S88. I want!
Old Oct 25, 2006 | 02:15 PM
frcefed98's Avatar
Me too, one day....**** I'd take a S78 as well.
J
