Injector questions
Old Oct 25, 2006 | 09:20 PM
Slow00ls1T/a's Avatar
Default Injector questions
How bad will the car run with 42lb injectors compared to the stock 26
if the injector duty cycle is above 80 % will a fuel pump bring the number down due to increase in pressure
Old Oct 26, 2006 | 08:40 AM
Old Geezer's Avatar
Exclamation WHOA there!!
"How bad"?? What do you mean?
Without some background info, that ? is totally confusing.
Duty cycle of which inj?
Why 42's to begin with?
What's the op pressure to begin with?
What is the FWHP target?
How are you going to achieve your target? Blower, NOS, ??
Old Oct 26, 2006 | 09:00 AM
the first part of the question i was refering to the tune
the reason im going with 42lb is i currently have heads and cam and there is more planned in the future so i dont want to buy injectors twice
Old Oct 26, 2006 | 09:23 AM
code4's Avatar
The 42's will run no different than the stockers if tuned correctly. They just have more capacity.
Old Oct 26, 2006 | 09:47 AM
what about with out a tune
slow trap's Avatar
if you plan on more mods i would go ahead and get a bigger pump also along with the injectors.
Old Oct 26, 2006 | 09:57 AM
code4's Avatar
Won't run, you have to put the injector flow rate in your tune.
Old Oct 26, 2006 | 11:53 AM
98redorangeta's Avatar
You need to have the tune done again or the car will run like **** if it runs at all. You shouldnt be to far off if you just change injector flow rate it would take like 2 min to flash in the new ifr table. If you have adjustable fuel pressur on the pump then you will be able to compinsate for the new injectors but you would still probably need it tuned for the extra fuel that would be coming in from more fuel pressure at low rpms. You need to upgrade the fuel system to make big power just go a head and buy a new pump and injectors and you will be set for a while on you fuel system.
Old Oct 26, 2006 | 08:23 PM
Ya already ordered the racetronix fuelpump and harness
