- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
thanks
The LTFT will tend to tell you how far off the tune is from stoich and the IDC will tell you how much injector capacity you have for the volume required. The AFR needs to be adjusted for the fuel mixture being used however a flex fuel vehicle has the ability to know the amount of ethanol in the fuel. I don't have FFV so I am not sure how they behave, I adjust the afr's in mine to comply with the fueling required.
I have a D1-SC Procharger with a forged 383 running 60lbs injectors and an upgraded fuel pump. Injectors are at 85% capacity and I am running only 8psi.
My tuner tells me I need approximately 30% more fuel injector and pump capacity to equal the same power as I do with pump gas. (560whp)
Do I really need to change anything? I was under the impression I could just tune and move on.
i made 580/660 with the same injectors/inadequate fuel pressure and pushing against 12-15 psi on a stock ls2 GTO.
You'll be fine at <600 if u have good fuel pressure.
Good tuners will always push you to be safe, they don't want you blaming them.
For sure if you keep the above in check all is good. I suspect you will need to make some changes to keep her safe and reliable.
I could only find 1 that was 1 bar, MAF, OEM injectors. Al the others are 2 bar SD, 60#Deka. All are E-85. These are for use with the stock cam. Do a compare with your OEM and make sure there isn't something I forgot. Like injector size or 2 bar SD.
These are NOT actually zipped. I had to rename the damn file because they were too big. Rename them to .hpt
