- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
CAN THE MODERATOR CLEAN THIS THREAD BY DELETING ALL OFF-TOPIC RANTS? MAYBE MOVE UNRELATED RANTS TO "WHY NOT TO RUN E85"?
im a clean freak when it comes to my car. i dont think i could bring myself to put that much money into using it though with injectors tuning and all that though. if i had the cash id prolly do it.
just curious what would it hurt if i used it in my tank?
i mean from what ive read (not that i know anything about this) but could you use this almost the same as like an additive of sorts?
A few gallons in a tank is a great octane booster
Has anyone had to change the rubber lines in the fuel tank?
I noticed a drop of 5 to 6 psi under idle recently and thought something was going wrong with my fuel pumps. I have 2 walbros; 2nd one comes on under boost. I pulled the pump buckets and barely tugged on one of the lines and it came off!. I checked the other connections and all where loose. Did a little research and appears E85 with alcohol content is eating the rubber from the inside out. I'm looking fuel lines for the pumps that are resistant to alcohol but wondering if you Sweden guys who've been running longer than I (3 years) on E85 have had the same issue?
The best way to tell is with a fuel pressure gage, get an extension to run it under the hood onto the windshield and take it for a spin.
Methanol will drop out solution above 10% and you will need a blending agent to keep it mixed. Methanol is more corrosive.
I don't believe this will be an issue just for using e85 unless you are up in HP. My Z06 I run the stock fuel pump with a fuel pump hot wire and IDC 1000 injectors and it works very well on E85 with only 28-30% IDC at top rpm's. The same setup with stock injectors would run 88-94 IDC on gas and would not allow enough fuel volume for much ethanol %. My Z06 is near stock with only a CAI and Corsa exhaust. You wont save any MPG $ on running e85 but it's beautiful high performance fuel and cheap for race fuel.
As you add ethanol the amount of fueling needs to be richened in the tune or it will run lean.
My truck can run more ethanol with stock injectors but it's because it does not see higher rpm's. The OEM's do not give you much excess injector
on gas vehicles.
Hope this helps.
You can use HP Tuners or anything that gives you injector duty cycle and LTFT's (long term fuel trims). The e85 will need more fuel for stoichiometric and that will show up in your LTFT's which will go higher as you add ethanol. If you have adjusted the tune for the bigger injectors then they will have the capability to provide the volume necessary BUT if you are running out of fuel pump capacity they will still trying to provide enough fuel without enough fuel volume from the pump, the result is still insufficient fuel.
on gas vehicles.
Hope this helps.
http://www.hptuners.com/forum/showthread.php?t=36971
Cranking tables
On my Vette engine/fuelcontrol/general.
Timing is an area I have not fully optimized yet on my Vette. Some areas may take more timing but I am not sure it's worth much since it's mainly my DD.
I use to run a drag only Anglia gasser BBC on methanol and in that car 38 total was what it liked. I tried going higher but neither et's or mph where better.
LSX heads are more efficient and may need less timing. I would suggest not take a 3-4 degree across the board approach, maybe add 1-2 degrees at a time, and only in the RPM cyl air mass range you are going to be in. Others may differ I don't believe in taking timing to the raged edge for most racing these days.
