- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
I use HPT which is laptop based like EFI Live or LS1 edit. The laptop software lets you tune much much much more stuff and at finer and coarser levels than a hand held. But if you don't have a laptop......
I used a Predator, which I still have, for years before I bought a laptop and HPT. The good thing about the hand held is mine is in the pouch behind the seat if I ever need to switch back to Gas unexpectedly.
I also ran this motor at 8 psi with 42# injectors and a single Walboro on the dyno and showed an AFR of ruffly 13.5:1 and it still didn't knock.
Nor has my new motor @ 13:1 and 8 psi with same timing table.
Now I'm saying wont, but I have never seen it knock.
"Understanding Air/Fuel ratios
This article assumes you already understand the concept of the air/fuel ratio (AFR), but if not, familiarize yourself by visiting this Wikipedia link. You may have already read that E85 has a different stoichometric air fuel ratio than gasoline's 14.7. The stoich AFR for E85 (at 85% Ethanol) is 9.76. The stoich value represents an ideal perfect burn of the fuel usually used at part throttle conditions. Full throttle conditions require a richer mixture than stoich to prevent the dreaded detonation, or pinging.
However most AFR gauges you can purchase to display a numerical value of the AFR, are showing you values for gasoline. This is where it can get tricky, and it's important to understand how this ratio works on both gasoline and ethanol-based fuel.
All AFR's regardless of fuel type work off of a common number called Lambda. A value of 1.0 in Lambda represents the stoich for any fuel. Gasoline is Lambda 1.0 at stoich. E85 is Lambda 1.0 at stoich.
If you already have a standard gasoline AFR meter hooked to a wideband O2 sensor, you can still use the displayed gasoline AFRs in determining your engine's true AFR. For example, if your gasoline meter is showing 14.7, then we know this is Lamda of 1.0. The equivelent on the E85 side is around 9.7. Therefore you can conclude that the 14.7 you see on the gauge is a true AFR of 9.7. This allows you to effectively use existing gasoline AFR components or software to tune an E85 Mustang without buying special equipment. Simply use the same target AFRs on your gasoline gauge that you normally targeted for gasolline. "
So basically you'll still set your cruise at 14.7 gas a/f = 1.0 lambda = 9.6ish actual a/f. And change your target a/f at wot to 11.80. Then scale your VE table accordingly.
I would be very interested in this as E85 NA Info seems to be a little harder to track down. With Milled 243's, BBK SSI, Full Exhaust I decided this would be a good time to start playing with E85. I am running 42lb injectors.
I added 5* across the board and it obviously doesn't knock but feels like I lost a little so I was going to start backing it off.
Either way, thanks for the help so far, just want to get a few more answers for the time being.
