- Camaro and Firebird: What You Need to Know About E85 and Race Gas
Important information to help you understand your Camaro or Firebird.
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
How to run your LS1 on E85
There are some "boxes" on the market that claims that when connected you can run anything from straight E85 to straight gasoline.
As I understand, what these boxes do is to richen the overall fuel delivery and relying on the fuel trims to be able to compensate.
My question is this: On a stock LQ4 engine would it be enough to richen the VE table by say 10% ?? I was thinking it is no need to buy a $450 box if I can do the same with my HP Tuner.
Here in Norway it is not practical to tune for straight E85 since there is only a few gas stations that carry E85 unlike in Sweden where it is all over the place......
But if you want to run gas also then add 15% to ve, but remember that the PCM and stock lambda dont work very well over 4000rpm.
Your messured AFR is 10.9, if you had 20% gas added to the E-85 you put in, that would make the ethanol/gas blend 35% gas and 65% ethanol.
The stoich value for E-65 would be right around 10.9
Your car is running the way it is supposed to.
Run out the tank you are on until it is nearly empty, then refill it with E-85 and you will be right where you want to be.
You should not set the stoich value to anything but stoich. If you are having fueling issues you need to tune the car.
If after the new tank your AFR is still off, there are lots of ways to fix the fueling, some better than others.
People will change the injector table or the MAF table or tune the VE table or all of the above. If you don't know how to do this, I suggest do alot of reading/learning before you try. It's not hard to make a mess of things, the PCM will make the adjustments for you until then.
When I switched my truck over, all I changed was the stoich value and it runs fine. I haven't checked it with my wide band to confirm it's right but I just passed emissions so why bother. I have my hands full with my car right now.
Very simple, basic, FYI. You can use up to a 50/50 mix of gas/E-85 without doing ANYTHING to it. IE, tuning. The ECM will adjust to richen the mixture up to about 20%. Then you will get a CEL after going farther...
E-85 requires about 25-30% more fuel so, Moving from 30 to 40# injectors adds the correct amount with little to no tuning. But why buy injectors and not add some headroom?
I've ran Walbro pumps for over a year with E-85 without trouble.
At 11# of boost 92 octane with 3 gallons of E-85 added to the tank runs great and allows timing >20 degress.
At 15# of boost that mix gives out, more KR than total timing. I saw about 3 degrees total timing and lots of KR.
At 15# of boost on E-85, with 190 degree air intake temp, and 25 degrees of timing I had no KR. It's hard to get that much fuel flow though. 60# injectors and Walbro pump are all maxed out.
All on stock LS2 GTO engine.
When I was N/A and bone stock I gained 20 hp and 30 tq with E-85. I have dyno charts posted on ls1gto.com
instead of messing with ve and maf, or stoich, I'd use the injector table first and leave stoich at 14.7.
If you moved from stock 30# injectors to #42 then that makes you %40 richer all by itself. It should be running about %10 rich with E-85 on the oem tune in that case. Close to where you need to be without any tuning AT ALL. Then all you need to do to get LTFT's right would be to lean it out about %10 across the board.
This all assumes you kept the OEM 4 bar fuel pressure.
- Any submerged fuel lines do need to be upgraded. In a C5Z only the fuel pump/pickup are submerged, no lines correct?
- The fuel-sock needs upgraded. Did any of ya'll run into that?
- Other open issues?
-TJ
