Old May 26, 2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
How to run your LS1 on E85
Old Jul 23, 2008 | 02:29 PM
  #381
BADSZ28's Avatar
I too am OLSD. So other than stoich and spark, the tune was left alone as far as switching to E85?
Originally Posted by DirtyJohn
That was done, Spark was raised globally as well as idle spark.
Idle spark is sitting somewhere around 26-28 and pretty solid.
I can't speak for what your trims will do when switching.
I'm currently OLSD so there aren't any real adjustments that get made by my comp when I switched. I was still in the process of getting the 42# injectors in line so what my VE looked like before wasn't really indicative of what it is now.
I prob won't ever get a chance to get it dyno tuned to make the most effective spark changes either, which stinks.
Old Jul 23, 2008 | 04:29 PM
  #382
DirtyJohn's Avatar
Effectively yes, but like I said, my VE and injector stuff were not completely done before the switch.
To better answer the question, if you switch those two things and expect that your VE will need tweaking, yes that's all that was done.
Keep in mind tho, I am just some schmuck that read a couple internet threads and applied that info. I'm still just learning like most people here.
Old Jul 23, 2008 | 04:56 PM
  #383
BADSZ28's Avatar
Keep us posted on results.
Old Jul 29, 2008 | 09:02 AM
  #384
DirtyJohn's Avatar
Well 1 year later and only a conversion to E85 gave me +13 hp and +16 lb/ft Torque.
Last year graph 92 octane and poor tune....
This year graph, E85 and better tune..
Sorry to leave the results a little ambiguous since the original tune was questionable, and honestly the current tune could be questionable as well since I'm no tuning pro
(although I did get some good advice) still,..you can't deny there's a gain to be had from this fuel.
Mods in sig, still stock compression, basically small cam and bolt-ons.
~T
Old Jul 29, 2008 | 02:37 PM
  #385
L337HomerSimpson's Avatar
Does anyone know how much I could boost compression naturally aspirated?
If a stock LS7 (for example) runs 11:1 with 91-93 octane what compression could someone theorectically run with a engine dedicated to running soley E85 100% of the time?
Old Jul 29, 2008 | 04:59 PM
  #386
vaticano's Avatar
I'm setting up my new motor at 13:1 with boost. I read one guy is running 15:1 N/A. There is an SAE paper where they modified a diesel motor for E-85, and I believe they ran it at 20:1.
Old Jul 31, 2008 | 01:14 PM
  #387
15:1 NA sounds pretty good.
It is too bad E85 isn't more readily available in all 50 states because with the compression increased to compensate for the octane I bet some of the fuel efficiency would come back compared to straight gasoline vs E85 at normal compression ratios.
Old Jul 31, 2008 | 04:55 PM
  #388
vaticano's Avatar
Agreed, and maybe the auto manufacturers could start building E-85 only motors.
Old Aug 4, 2008 | 09:06 AM
  #389
kgkern01's Avatar
I have to rebuild by LT1 and am going 383, I am debating building it up with more compression to run E85 only, or maximum compression for pump gas so I could change back if needed.
Old Aug 4, 2008 | 07:10 PM
  #390
Irocss85's Avatar
ive heard of people running 12.5:1 on pump gas, but you'll need just the right cam and tune to do it.
Old Aug 4, 2008 | 08:06 PM
  #391
waterbug1999's Avatar
If you are talking about pump gas being E85 and/or 100 / 110..
You run that high of CR and throw 93/92/91 octane its gonna ping.
Old Aug 19, 2008 | 12:41 AM
  #392
Mike96z's Avatar
this looks cool. as far as compression on pump gas, ive done 12.1:1 on pump gas.
Old Aug 19, 2008 | 05:49 PM
  #393
Irocss85's Avatar
Ive read about people doin it. large cams though to bleed off press. and more of a strip/street car then street/strip.
chris
Old Aug 20, 2008 | 05:09 PM
  #394
Dan Brown's Avatar
ahhh man I can't wait to do this. I ran some quick numbers and the E85 in Colorado was about 15 cents cheaper per energy content per gallon than gasoline (that was assuming it had 70% of the energy content per gallon, i think that's close?) Thanks for the write up!
Old Aug 28, 2008 | 05:07 PM
  #395
rons 00z's Avatar
whats the chances of getting somemore info on this?
Old Aug 28, 2008 | 08:42 PM
  #396
vaticano's Avatar
I found them. They came from the first link.
https://ls1tech.com/forums/showthrea...=602091&page=3
http://www.epa.gov/otaq/presentation...-isaf-no55.pdf
http://www.epa.gov/otaq/presentation...mjb-051303.pdf
Old Sep 18, 2008 | 10:38 PM
  #397
98_1LE's Avatar
There are a couple places close to me where I could buy E85, and am interested in using it with higher compression for more power.
Old Sep 29, 2008 | 12:31 PM
  #398
01Blk*SS*'s Avatar
great write up!!!
Old Oct 5, 2008 | 08:44 AM
  #399
Runn's Avatar
Originally Posted by 01Blk*SS*
great write up!!!
Thanks.
Old Nov 10, 2008 | 08:48 AM
  #400
maxgee's Avatar
Put E85 in over the weekend and got about 185miles on it so far. I am impressed with the results so far. Seems to get into boost faster, car sounds different and I noticed in a given gear and rpm I'm the motor has less load on it. My injectors are maxed out bad at 149% at full boost, looking for bigger injectors now. I currently have 42lb injectors from 04 Cobra. Using gas I was at 95 % inj duty cycle under full boost (8lbs). So far I don't think I'm going back to regular gas.
p.s. I did tune my set up with Hptuners with the parameters suggested by RUNN.
