Old May 26, 2016, 04:18 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Fuel System Guides
Print Wikipost
How to run your LS1 on E85
Old Jul 6, 2008 | 06:50 AM
  #361
fil131's Avatar
Originally Posted by Schwanke Engines
Yes, just change the stoich number, save the cal as a new file. Reload it and you will see that EFI Live has changed all of your other numbers. You will be good to go.
Is this the same for HPTuners?
Old Jul 6, 2008 | 07:06 AM
  #362
Runn's Avatar
Yes, it works on hptuners too.
Old Jul 6, 2008 | 07:17 AM
  #363
fil131's Avatar
, cant wait to see what E-85 does for my APS twins.
Old Jul 12, 2008 | 09:47 AM
  #364
kgkern01's Avatar
SO has anyone tried different timing with E85? I have my LT1 running on E85 for a month or so now and had advanced my timing 2* across the whole timing map vs my gas tune. I wanted to know if I should tune back or what other people have found to make the best power?
Old Jul 12, 2008 | 11:35 AM
  #365
vaticano's Avatar
I advanced the timing in my stock truck and it felt slower. I then put the timing table from my car in the truck and it runs great. Even picked up 1 mpg. I have read that if you are set up for max hp on gas then you wont need to change the timing. Unless you go FI, then adding timing really wakes it up. Best way to know for sure is to take it to a dyno and experiment. Every setup is different
Old Jul 12, 2008 | 12:32 PM
  #366
kgkern01's Avatar
I dynoed last weekend and from the initial 2* advance, tried upping it by 1* for the 2nd and again .5* on the 3rd dyno pull for upper RPM and MAP. This only resulted in about 1 hp and 2 tq increase vs where I was at. So should I just leave it where it is with the initial 2* would you say, or at the advanced 3.5*?
Old Jul 12, 2008 | 04:43 PM
  #367
vaticano's Avatar
I would leave it were it was, at +2* just to be on the safe side. With a gain of less then 1% it could have been from many different factors and not neccessarly the timing.
Old Jul 18, 2008 | 10:52 AM
  #368
BADSZ28's Avatar
I would think that one of the advantages of running E85 was to add more timing for more power. Maybe you do not get that much more power at peak but do under the curve??? I am thinking of doing this on the Camaro and increasing timing down low to improve MPG and responce. Anyone have any experience with these changes?
Old Jul 18, 2008 | 09:22 PM
  #369
fil131's Avatar
You can advance it further as long as you dont have knock, and as long as you do not start losing power.
Once you see knock or power loss dial it back.
Old Jul 18, 2008 | 09:48 PM
  #370
vaticano's Avatar
That is the only issue I know of. E-85 does not knock. I ran mine at the dyno at an AFR of 14:1 at 6300 rpm and had no knock at all. So it is entirely posible to advance the timing to far and damage something without knowing until it's to late.
Old Jul 20, 2008 | 07:39 PM
  #371
VH5150's Avatar
Dynojet Fan
does anyone have a chart that shows what a specific AFR = in E85 values... ie.. E85 stoich = 9.765.... gasoline stoich = 14.63.... can we get a list that starts at stoich and goes down all the way to say 10.00 AFR???
THANKS
Old Jul 20, 2008 | 09:33 PM
  #372
kgkern01's Avatar
THANKS
Just divide the E85 stoich value by the gas stoich value to get the conversion factor. Ex: 8.0 E85 = ~12.0 gas
Old Jul 21, 2008 | 12:08 AM
  #373
fil131's Avatar
What do you mean when you say you can damage the engine without knock?
Does the temp start to get too hot?
I'm not a tuning pro but I always thought you could advance timing as far as you wanted so long as there was no knock? And if power loss started to show up then you had reached your timing advance limit on that particular setup?
Old Jul 21, 2008 | 05:38 AM
  #374
VH5150's Avatar
Dynojet Fan
since im kinda stupid w/ this stuff please give a better example... thanks...
edit..... i think i got it.....
12.5(afr) x 0.667(conversion factor) = 8.3375(afr) in e-85 values... now all i need to do is rescale my lc-1 in the logworks programmer...
Old Jul 21, 2008 | 03:14 PM
  #375
vaticano's Avatar
Many tuners do not recommend tuning via KR. I have never done it myself, but have been told that you can advance the timing to far and still not get any knock retard. Many people don't tune on a dyno, rather, they tune on the street. Tuning this way only allows you to monitor knock retard, not horse power. If you don't get any KR you wont know what to far is. If you tune on a dyno, then yes you can advance timing until the power decreases, then back off.
https://ls1tech.com/forums/showthrea...+timing&page=2
Originally Posted by Robert56
Yea, there are a lot of methods out there, and forgive me, but I like to use the ones that are correct. Reading your plugs for your indicated timing mark is the way to do it (if you don't have access to a dyno), and including strip tuning you'll be able to tune in for max power. Even with a dyno and knowing max power, reading of the plugs are still benificial, with actual track time to back up dyno. Setting it to KR and then backing off till it goes away tells you what? We want volumetric efficancy and we won't be getting that with guessing about the timing and/or peak timing to be used. To many think the most timing is the way to go, not true, and actually a little dangerous if any little issue crops up, you could go instantly to detonation, not good spraying or not. If your forced to use your method, i would go back further than just till knock goes away, just for added piece of mind in the safety department.
Robert
Old Jul 23, 2008 | 01:18 PM
  #376
DirtyJohn's Avatar
I'm officially converted, tune wise that is.
Running through the 2nd tank of gas right now.
It may not be ideal but its running pretty solid and my fuel is almost spot on.
Will be on the dyno this weekend so I hope I don't blow er up.
Old Jul 23, 2008 | 01:44 PM
  #377
BADSZ28's Avatar
What did you do to change the tune? Just change stoich value?
Old Jul 23, 2008 | 01:46 PM
  #378
BADSZ28's Avatar
If I change my stoich value and my VE is already tuned; when I run on E85, what is my wideband going to read at idle and light throttle if I leave it set for gas and it was reading 14.7 with gas?
Old Jul 23, 2008 | 02:07 PM
  #379
DirtyJohn's Avatar
That was done, Spark was raised globally as well as idle spark.
Idle spark is sitting somewhere around 26-28 and pretty solid.
I can't speak for what your trims will do when switching.
I'm currently OLSD so there aren't any real adjustments that get made by my comp when I switched. I was still in the process of getting the 42# injectors in line so what my VE looked like before wasn't really indicative of what it is now.
I prob won't ever get a chance to get it dyno tuned to make the most effective spark changes either, which stinks.
Old Jul 23, 2008 | 02:08 PM
  #380
Schwanke Engines's Avatar
LS1TECH Sponsor
THANKS
Grabbed this from EFI Live. It is the GM flex fuel table.
