How much timing are you running at WOT?
Someone correct me if I'm wrong
Robert
Robert
Reading your plugs for your indicated timing mark is the way to do it (if you don't have access to a dyno), and including strip tuning you'll be able to tune in for max power. Even with a dyno and knowing max power, reading of the plugs are still benificial, with actual track time to back up dyno. Setting it to KR and then backing off till it goes away tells you what? We want volumetric efficancy and we won't be getting that with guessing about the timing and/or peak timing to be used. To many think the most timing is the way to go, not true, and actually a little dangerous if any little issue crops up, you could go instantly to detonation, not good spraying or not. If your forced to use your method, i would go back further than just till knock goes away, just for added piece of mind in the safety department.Robert
Robert
Robert
Mine runs 28* mostly until 6k then ramps to 30.5 and it runs beautifully.
Every motor is different and should be treated as such I think.
cheers
