View Poll Results: Poll: How many degrees of timing are you running at WOT?
<23 degrees...or stuck on low-octane table
34
10.79%
24 degrees
19
6.03%
25 degrees
16
5.08%
26 degrees
45
14.29%
27 degrees
43
13.65%
28 degrees
86
27.30%
29 degrees
23
7.30%
30+ degrees
49
15.56%
Voters: 315. You may not vote on this poll
How much timing are you running at WOT?
Old Oct 18, 2008 | 09:17 PM
  #61
02 BLK WS6's Avatar
My initial tune had 29*. I have been messing with it at the track and bumped it to 31* and the car picked up 1.5 mph and .1 in the 1/4 mile.
Old Oct 19, 2008 | 11:01 PM
  #62
Vrbas's Avatar
22... wait that's low?
Old Nov 5, 2008 | 10:10 AM
  #63
Gh0st's Avatar
Jedi Master
Only if you have no idea what you're talking about.
Old Nov 15, 2008 | 10:34 PM
  #64
2000WS6ICK's Avatar
28* and 12.5 AFR at WOT, no Knock.
Old Dec 7, 2008 | 06:51 AM
  #65
the_merv's Avatar
Veteran: Air Force
32* with L92 Heads. Cam is on a 114+3 LSA.
Old Jan 10, 2009 | 10:18 PM
  #66
WS6RED2002TA's Avatar
23.5 any higher and I get KR. AFR is set at 12.7
Old Jan 11, 2009 | 09:35 AM
  #67
moehorsepower's Avatar
As said there are "Many" factors that contribute to the amount of timing that is optimal to each specific combo, Not only engine specs, quality of gas, altitude, air ect...But agreed that to keep adding timing until you hear knock is the WRONG way to do it. People without Dynos can do it at the track. Like others said where they picked up MPH is one way, Do not go by E.T. I read where some people tell others with power adders such as Nitrous or forced induction to keep adding timing until they hear knock then back off. Well let me tell you, in a power adder configuration if you do that, it will probably be your last. I have even read where someone was telling nitrous users to use the hottest plug they could find but just to close the gap on the plug!! So just dont go by what everyone else is doing, go by what your combo likes....
Old Jul 20, 2009 | 04:10 PM
  #68
NAVY99B4C's Avatar
Default hp tuners, 40 degrees of timing is wrong?
my car on hp tuners with my cam only swap is saying 40 plus at WOT? picks up no knock at all ever? cant hear it either? should i try another tuner?
Old Jul 20, 2009 | 04:37 PM
  #69
69LT1Bird's Avatar
I would RUN not WALK to a new tuner immediately.
